Thread: Automatic transmission fluid capacity
Results 1 to 8 of 8
    The War Wagon BrydonJ's Avatar
    Dec 2009
    Rockwall TX
    Question Automatic transmission fluid capacity
    I have a 1988 Chevy C1500 and I need to know what my transmission fluid capacity is. So if anyone knows that would be greatly appreciated. Also, what kind I should use, and if there are any good additives.
    Brydon Jordan-1988 Chevy C1500 5.7 Liter-
    Aug 2008
    Jackson, Missouri
    Re: Automatic transmission fluid capacity
    about 5-6 quarts just for a pan drop. Use either Dexron 3 or GMs latest fluid. Dont use any additives.
    Dec 2009
    Rockwall TX
    OK thank you, I gotta go find out how to do this
    Aug 2008
    Jackson, Missouri
    Are you just changing the fluid and filter in the pan?
    Mundelein
    its easy just unbolt the pan disconnect the shift cable and let the pan drop carefully and fluid will pour out...then romove the filter giving it a pull down and replace with a new one...clean pan and gasket real good and then reinstall pan...after tightening all bolts and connecting the shift cable refill through dipstick tube start with 5 quarts and check
    RAGMC ragmc's Avatar
    Dec 2004
    Gilbert Az
    I would only use 3-4 quarts if your droping the pan you dont want to over fill it, then Id get it up to temp and add if you need to.
    Registered User jake760's Avatar
    May 2009
    USA
    Mine takes 5 quarts, 4l60E deep pan.
    Dec 2009
    Rockwall TX
    Ok, that's all I'm trying to do. My gears aren't responding very quickly when I drop into reverse. So i'm hoping that will fix it.
