Thread: Heater only blows luke warm air
Results 1 to 20 of 27
    Chevy newbie 99silveradoLS's Avatar
    Dec 2008
    Missouri
    The heater is my 99 nbs won't blow really hot air like my smaller ranger. What do I need to look at or have serviced? I read somewhere that a clogged cabin air filter could cause this but haven't checked that yet because it's been frigging cold outside and I've been driving my Ranger.
    1999 Silverado LS 4x4 Z71 w/ 5.3L
    Head Cook mrgrim's Avatar
    Jun 2008
    Philly
    Re: Heater only blows luke warm air
    Is the truck warming up to normal motor temp? Coolant full? heater core and air box full of dirt? Blend door moving all the way?
    Thats where I would start
    04 ECSB 5.3 4x4 Z71
    06 Front clip, Reflexion steel hood, Escalade touch screen nav, Escalade wood steering wheel
    06 E Fans and Rad, 2 Alpine subs, 250 amp MechMan alternator, Dual battery with isolator
    05+ front brake swap, Suburban rear brake swap,Rusty door bottoms,Line X,PCM4Less tune
    Dec 2008
    Missouri
    Thanks for the starting points.
    The truck warms up normal. Coolant is full. I will check the air box and heater core. What's the blend door?
    Big Jake BigJake's Avatar
    Sep 2006
    louisiana
    My son had this problem on his 02 Z71. He removed the hoses from the heater core and blew it out with air and then a water hose. Heater core was restricted. Works great now.
    2004 2500 ccsb 6.0, Superchips, 265/75/16 Toyo A/T's.
    Cape Cod, MA
    This is the time of year when this sort of thing becomes very common. NBS trucks typically suffer from either clogged cabin air filters or a clogged heater core, or maybe both at the same time. The heater core back flush is very easy to do, and if that doesn't resolve things, go after the cabin air filters.
    Dec 2008
    Missouri
    Well I just changed the cabin air filters and you were right, they were FILTHY! I doubt they have ever been changed and truck is 11 years old with 200k miles. I'll let you know if that fixes the heating issue. I'm hoping it does since they were so nasty.
    Cape Cod, MA
    No heat usually means a clogged heater core if everything else is fine. Warm, but not hot air, is usually a pair of clogged cabin filters. I bet replacing your filters has made a big difference.
    May 2006
    MA
    The heater core probably needs to be bled. If the core is full of fluid and there is air in the feed side (WP Out) hose the air will act like a spring. The air will compress, but the WP doesn't have enough "Umph" to push the air bubble combined with the weight of the fluid inside the core w/out winding the pi$$ out of the motor. I take the hoses off the core and blow the fluid out of the core using compressed air. Be careful, the fluid will spray all over the engine if you don't do something with the other tube. I usually use a large towel. Reconnect the hoses, add fluid and run the engine.
    Aug 2002
    SYRACUSE NY & ALEXANDRIA BAY NY
    I would try a blend door reset ! Its easy and free:
    It is most likely the Blend door actuator.
    BUT before you go to the dealer try the reset procedure thats
    been floating around on the GM forums:
    Try looking for the HVAC fuse under the hood.
    pull the fuse for about five minutes, reinstall it then turn the ignition on don't touch the controls for another 5 minutes. The system will run through all the settings.
    Rest In Peace #3 intimidator4x4's Avatar
    Dec 2007
    Southeastern Indiana
    Does this reset work on the pre 99 trucks (OBS)
    V INTIMIDATOR has been SOLD V
    98 RCLB Z71 all stock
    Registered User swb lt1's Avatar
    Nov 2009
    arlington, tx
    i would try blowing air through it first. just disconnect both of the hoses and blow air through one side of it. i had this problem and this fixed mine, it was just clogged up.
    1993 GMC SIERRA with 1996 corvette lt1. Built 4l60e. 4.10 gears. Eaton positrac. Dual exhaust. 1996 dash swap. 2002 electric tahoe seats. More to come
    Dec 2008
    Missouri
    It made a pretty good difference in the amount of heat that it puts out now. It's not super hot like in some trucks, but it's warm enough now that I get uncomfortable if I wear anything besides a shirt when the heat is on.
    Registered User Afterdark's Avatar
    Mar 2006
    idaho
    take the two hoses going to the heater core and swap them for a couple days prob the dex cool (evil satan juice) pluging up in the core if so this works every time :)
    Indiana
    You just might need a new thermostat.
    Kentucky
    which FSC's came with a cabin filter?
    Dec 2008
    Missouri
    It got a new thermostat put on last year. I'm going to do the heater core flush still and see if that helps even more as well as due a full coolant flush and clean because it needs it. My truck is a 99 NBS and it has the two cabin air filters. From what I read it was the 99-02 nbs trucks that had them.
    Nov 2009
    arlington, tx
    i would almost put money on the fact that the heater core is probably clogged. just shoot some air through it from both ways and hold a rag on the opposite pipe each time and see what kind of nasty crap gets blown onto the rag.
    Honorary Mythbuster neonhomer's Avatar
    Volusia County, FL
    Here is a twist. I had to clean my negative battery cable. When I put it all back together, the heat doesn't work anymore. It worked fine before I did the cable cleaning. I am going to try to do an air door reset and see if it helps...
    NeonHomer
    2004 Chevy Silverado 1500 2WD Ext. Cab 5.3L/4spd
    1994 Dodge Caravan 3.0L/4spd
    2004 Harley-Davidson Road King Police FLHP/I
    Millbury, Ma
    its sounds like the heatercore is clogged. the stock fluid gm used for a short peroid of time ate away at the heatercore which was causing the problem you are having. i had the same problem on my 2000 and i flushed the heater core now it works great.
    Dec 2008
    Missouri
    Should I disconnect the hoses from the water pump and flush from there or get a quick disconnect tool and remove the hoses from the heater core and flush from there? Does Oreilly's carry the tool for disconnecting the hoses? We accidently broke the inlet hose the other day changing the intake gaskets and ended up just using a screw clamp to secure it back to the heater core pipe because the quick disconnect tool that we had on hand wasn't working. I'm thinking it maybe wasn't "long" enough to unclip the "quick disconnect".
