Thread: 93 K1500 No Spark
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
    Jan 2010
    Tampa, FL
    93 K1500 No Spark
    I have a '93 Chevy K1500. It was idling and then shut off. I now have no spark at all. Any thoughts?
    I replaced the ignition switch, and the purple wire from the ignition switch got real hot and burned some of the shielding off. It turns over with no issue, but still has no spark....Crank sensor?
    Pacific NW
    Re: 93 K1500 No Spark
    Check under your dist cap for any ugliness. Most parts stores can test the ignition module (kinda).
    89 K3500 RCLB- Fat Snarling RAT..Scat/Eagle/Crower/Crane/Edelbrock/MSD..TBI/EBL/TH400/Dana 60
    Jun 2008
    Union, Missouri
    x2 on the ign module
    proud poppa reesez's Avatar
    shelbyville, indiana
    Quote Originally Posted by mudbuddy View Post
    if you let the smoke out of the wire you have a short. You will need to deal with that first.
    +1
    1994 yukon gt .........gone but not forgotten
    1988 silverado RCLB 4wd........sold
    1999 rcsb gmc sierra 1500, new toy
    Jan 2010
    Tampa, FL
    Quote Originally Posted by 1988 GMC 355 View Post
    Just got the truck so I will ask..where is the ignition module located?
    Sep 2006
    fairborn,ohio
    Under the dizzy...also check the magnet on top to check for cracks.
    If it does...it's time for a new dizzy.
    At least that was my case on my 94.
    Jan 2010
    Tampa, FL
    Quote Originally Posted by TEE View Post
    Dizzy = Distributor cap?
    Sep 2006
    fairborn,ohio
    yes...the magnet on top gets cracks in it which will not let the distributor pop up.
    If you do replace it...the new one will NOT look like the old one.
    They did away with that type of mag.
    Jan 2010
    Tampa, FL
    So what is this? It attaches via a cable to the Distributor. I am guessing the pink wire is the same one that heads to the Ignition switch on the Column. You can see it is slightly burnt at the head.
    Could this thing be the issue of why there is no spark?
    Dec 2009
    Logan WV
    that's the coil or ign. coil it can be tested as well, won't hurt anything.
    The ign. module is under the cap, take it off, and down in the bottom on the metal part is a module that's held on by 2 small bolts and a plugin.
    tee-boy
    Apr 2005
    texas
    that pink wire is the ignition wire from the ignition switch. It is hot when key is in run or start position. You have a red wire to the ignition switch on all GM's (battery power in) and pink is (ignition out to the ignition system (Distributor on an OBS).
    the ignition module (electronic ign module) opens and closes the circuit for the coil (it takes place of mechanical points used in older vehicles).
    I would test the pink wire w/ a test light. if it checks out, it is either the module, coil, or the distributor.
    94 Silverado 2WD; 408K miles; Built 4L60E
    98 Trans Am; TH 400; 4400 Stall; F.A.S.T. 90; SS Long Tubes; Madman suspension; Slicks and Skinnies on Bogarts; Electric Water Pump; 11.50 1/4 mile; 400 lbs weight reduction; Underdriven; Stock valvetrain; Ford 9", Strange Racing Brakes (Sold)
    Jan 2010
    Tampa, FL
    So basically see if there is voltage up to the top of the coil on the pink wire with the key in the "on" position
    Jun 2008
    Union, Missouri
    Yes that is correct.
    THat wire looks pretty bad too, I would try to replace or fix it so it doesnt short again.
    and a new coil, distributor cap and rotor may not be a bad idea either.
    Jan 2010
    Tampa, FL
    I do have voltage up to the top of the coil. I want to replace that wire, is it a direct run from the Ignition switch to the connector on the coil? So I am going to just replace the Coil, Dist Cap, Rotor Cap, IGN.
    MI/AZ
    Something has rubbed on the wire, the aircleaner will if the spacer isnt on the TB or an aftermarket air cleaner.
    Jan 2010
    Tampa, FL
    Could be, there is a K&N Air Filter on there. Would that cause it to short causing the no spark?
    MI/AZ
    Quote Originally Posted by ipstack View Post
    Is it an aftermarket air cleaner housing? If so its hitting the pos/pink wire and grounding out on the air cleaner housing.
    tee-boy
    Apr 2005
    texas
    Coil, Dist cap, rotor - all cheap fixes. If you change the ingnition module and it winds up being the distributor, you still haven't fixed the problem.
    Jun 2008
    Union, Missouri
    that is a good start, considering you just got the truck and you should replace that stuff any way.
    you can get taht wire from the dealer or an auto parts store I am sure.
    tee-boy
    Apr 2005
    texas
    could be the wire that runs from the coil secondary to the dist cap (typically purchased when you purchase plug wires - may not be bad idea to change those while your at it).
