Thread: 1" Throttle body spacer need linkage spacers?
Results 1 to 12 of 12
    Jan 2010
    PA
    I find that some places are saying these don't need the spacers for the linkage/cables. Is that true? i read about someone ruining their trans by not running on so I don't want to do the same
    WV Jeeper 94_c/1500's Avatar
    West Virginia
    Re: 1" Throttle body spacer need linkage spacers?
    Never heard of having to extend your linkage on a TBI. I did have to raise the linkage mount on my carb motor when I added a spacer.
    JoshTheCanadian
    you dont have to.
    Jan 2010
    PA
    Ok, well I saw this:
    The throttle linkages/tv cable were on a bad angle with the spacer. CFM-Tech included spacers and bolts just for this reason and they worked excellent.
    This is why I mentioned about the spacers for the cables. Here is the post:
    http://www.fullsizechevy.com/forums/...-thoughts.html
    Anyone? Is the CFM tech spacer the only one that includes these? Why would they include them if they were not needed
    West Virginia
    I bet it makes the company look better if it comes with more stuff, so you feel better spending extra money on their spacer.
    Jan 2010
    PA
    Ok. if no one else needed them I'll just go for the cheapy on ebay. If it comes down to it, I can always make something to lift up the cables.
    West Virginia
    When I put a spacer on my carb truck I used a 1 inch spacer from Tractor Supply under the bracket and I got an inch longer bolt.
    Registered User nufnuffz28's Avatar
    May 2008
    North Carolina
    The throttle is OK without any additional spacers. Worst part is loosening the bracket that holds the fuel lines to the bell housing so that you can bolt the TBI back down.
    Make sure you readjust the TV cable. There are instructions on here on how to do it easily.
    West Virginia
    I used fuel line extensions, so I didn't loosen any bolts on the bellhousing.
    And I didn't need to adjust anything.
    JoshTheCanadian
    Quote Originally Posted by 94_c/1500 View Post
    Cause you dont have a 700R4
    Jan 2010
    PA
    Ok. If all i have to do is adjust the TV cable, that's no big deal
    Registered User ALLOUTODA's Avatar
    Toronto
    i have a TBI with a 1"poweraid spacer, my cables are on a bad angle and the kit did not come with any other parts, it looks like the braket needs to come up as much as the spacer i put on, it having truble coming out of O.D, can anyone help plz
