Thread: Power Steering Fluid Change
Results 1 to 12 of 12
    Apr 2006
    Oklahoma
    I did a search, but couldn't find any links or sites that have directions on how to change/flush the power steering on a 2000 Silverado. Any help is greatly appreciated!
    Oct 2008
    Kansas
    Re: Power Steering Fluid Change
    I am wondering the same, and i have the same problem. I guess we'll both stay tuned!
    My thoughts would be to unhook the belt and the cooler lines, blow out the cooler, and give a couple of quick spins to the pump, hopefully getting some fluid to belch out. I would hope that by hand, there is no side load by the belt, and there would be a fluid film to protect it while one is trying to run it dry.
    Then i would measure all the drained fluid and put the same amount back.
    Sound good?
    If it doesn't someone please chime in and tell the best way.
    99 C3500 6.5L 5spd 4.10 130K
    96 C2500HD 6.5L 5spd 3.73 240K
    95 C2500HD 6.5L 5spd 4.10 135K
    95 C3500HD 6.5L 5spd 5.13 132K
    95 C3500HD 6.5L 5spd 5.13? 170K
    94 C2500HD Burb 6.5L 4L80E 3.73 300K
    93 K2500HD 6.5L 5spd 4.10 252K
    91 C1500, 6.2L 4spd 2wd 3.42 59K
    91 C1500 4.3L 5LM60 2wd 3.42 ??K
    las vegas
    I am a lazy person, I just go buy a 2 dollar turkey baster and suck out the old fluid, refill, drive for a few days then repeat.
    Depending on the truck, the return line should be connected with a hose clamp, you can pull that and pour a few quarts through.
    Thats the problem with Chevy pumps, they really do not leak. Every ford ever made seems to leak and squeal, thus keeping the fluild fresh.
    Sep 2006
    Tennessee
    You can also pull the return line, jack up the truck, start it and have someone crank the wheels back and forth while you add fluid. BE PREPARED.....THE FLUID COMES OUT FAST!!!!!
    TN
    The way I have always done it.
    Lift it up, take both lines off the steering gearbox. Let the fluid run out of the lines and pump. With the truck off, turn the wheels, the gear box will pump out some more. Then hook up the lines again. Fill the pump, again without starting the truck, turn the wheels and keep filling the pump. The gear box will push out most of the air. Once you don't see any bubbles, start it and you should be good to go.
    05 Cavalier
    Dec 2001
    nixa, Mo
    Quote Originally Posted by paintdrying View Post
    I do the turkey baster thing also. I like doing that better than removing lines.
    Wayne
    Hazel, KY
    I bought one of those fluid suction pumps at harbor freight.
    Sucked fluid out of reservoir, refilled
    after driving about 50 miles repeated process
    again, after driving about 50 miles repeated process
    after changing fluid three times the fluid started to look much cleaner.
    Truck had 87K with I changed the fluid and it was very dirty.
    Registered User chevysol's Avatar
    Oct 2009
    Alabama
    A friend told me to just open the bleeder valve a little bit and hook a small plastic tube to it like surgical tubing. Then just pump the brake slightly and the fluid will run right out. Repeat at all four wheels till all you see is clear brake fluid. Just make sure to keep the reservoir full or you will get air in the system. He showed me how to do one and it runs out real easy especially when you pump the brakes.
    2002 Silver RCSB 2WD
    Registered User jake760's Avatar
    May 2009
    USA
    I've got 169K on the original fluid.
    Oct 2008
    Kansas
    Quote Originally Posted by chevysol View Post
    thanks for the input, but this thread is discussing power steering flushing, not brake bleeding.
    Oct 2009
    Alabama
    Quote Originally Posted by GM Guy 1 View Post
    Wow, I don't know why I thought about brake fluid :P just disregard my post then.
    Apr 2006
    Oklahoma
    Haha. Yeah, I'll be sure to hold on to your first post for when I do the brakes. Thanks for all the input guys. I'm going to do it tonight.
