Thread: reverse lights come on when turn signal is on
Results 1 to 4 of 4
    Jan 2010
    Pennsylvania
    Alright, As the title says my truck is doing some funky things. When the right turn signal is turned on the flasher clicks rapidly. (like when a bulb is burned) However; the bulbs all light up, the right rear turn signal is dim, the reverse lights come on flashing (very dim). Additionally, when the problem occurs if I put the truck in reverse the right reverse light does not come on. This happens sporadically but seems to happen when the temperatures are at or below freezing.
    Any suggestions
    98 Silverado Z-71 5.7 Reg cab
    Kansas City
    Re: reverse lights come on when turn signal is on
    Could be your multifunction lever (blinker switch) these fail on the OBS trucks and cause strange problems.
    2006 Tahoe Z71
    somewhere else
    Indeed, most likely a bad ground. Either the taillight circuit board is flaky, ground wire from the rear harness to the frame is flaky, or connection to the circuit board. In that order.
    Richard
    Jan 2010
    Pennsylvania
    Got it! Mudbuddy and someotherguy are both right. The bad ground was because the connector from the wire harness to the tail light board is not making a good connection. May have to do some cutting and soldering.
    Thanks for the fast help!
