Thread: 1990 GMC low rpm stumble
Results 1 to 18 of 18
    Pennsylvania
    Question 1990 GMC low rpm stumble
    Hey all, I'm looking for some direction on my truck. I am running a somewhat stock 1990 GMC K1500. I have headers, K&N filter, and a Crane Compu Cam. I'm not sure of the cam specs off hand, If anyone thinks the cam is in question, I'll dig up the cam card.
    Problem is, There's a low rpm stumble. Sometimes it stalls flat on its face, most times it has a bad stumble under 2000 RPM. I've replaced all spark plugs, wires, cap and rotor. Map sensor, Temp sensors, and the throttle position sensor.
    I'm not sure where else to look.
    Any Ideas?
    Thanks!
    May 2007
    Maine
    Wink Re: 1990 GMC low rpm stumble
    It sounds like you are going to need a tune. All or most of the stuff you have added has caused the engine to run leaner now with the stock tune. You might also have a vacuum leak, which I would check for first. Good luck.
    Ignorance can be fixed....STUPID is FOREVER!
    Registered User tbiparts's Avatar
    Nov 2009
    Jacksonville, IL
    First step is check your timing. Next step check for vacuum leaks and most importantly you'll probably need a tune on that chip.
    Give Brian Harris a call 1-336-471-2827
    If you need any other parts or advice give me a call or contact me off the site www.tbiparts.com
    Jan 2010
    Canada
    Unplug the little hose from your EGR valve and put a nail in the hose to plug it.
    I had the same issue. This is what the GM guy did and it fixed it.
    Not sure what this did but it worked.
    He told me to replace the thing the hose was attached to. I did but that didn't fix it so I kept the hose plugged, been like 2 years no issues lol.
    Registered User romakdaddy's Avatar
    Jan 2010
    pamplico sc
    Quote Originally Posted by Soah View Post
    the egr control solenoid is bad and causing the egr valve to open prematurly.its basically causing a huge vaccum leak through the egr valve.the valve itself could be sticking open.id replace both.
    Dec 2004
    Elkhart IN
    i'm getting the same low RPM stumble, and it doesn't matter what gear the trans is in, or engine speed... and my EGR solenoid has been plugged for a year and a half. any ideas?
    Jan 2010
    pamplico sc
    could be a skip
    May 2007
    What's the fuel pressure set at. I had the same problem before turning up the fuel pressure.
    Registered User Jameslleary's Avatar
    Dec 2008
    Patterson, Ca
    Just unplug the egr solenoid......no need to plug the vacuum line
    1986 K10 Suburban
    350,TBI
    CFM-Tech Super Sucker
    Jet AFPR
    TBI heads
    Comp 12-388-4(260H)cam
    3" Walker quietflow SS exhaust
    Dec 2004
    Elkhart IN
    Quote Originally Posted by romakdaddy View Post
    could be a skip
    a what? we're talking about a truck, not playing Uno.
    Quote Originally Posted by ryan_thompson87 View Post
    14 or 15psi.
    May 2007
    You can try turning it up to 18 or so. I Don't specifically remember your setup but your running Vortecs right? And you have the same pump I do?
    Dec 2004
    Elkhart IN
    no, i'm not running the Vortec engine yet, still beating on the L05 relentlessly... the damn thing won't die!
    are you running the EP241 or the EP381?
    May 2007
    241. Just for fun, unplug the MAP sensor, (green plug, right by the IAC, I'm sure you know that) It'll force the ECM to go to a default fuel table and dump fuel to it. My stock regulator even made adjustable still couldn't put out the pressure I needed had to go to a XtremeFI unit. In the mean time while I was waiting for the US post office to make it to the Great White North, I just had ran with the MAP unplugged. Normally pig rich but as lean as I was it worked out O.K., I was a little rich at idle sometimes, but at least I could drive it and not get furious at it bogging from every light.
    Dec 2008
    Patterson, Ca
    Not knowing much about your steups, I will throw my $.02...
    *Cam a tooth or so off?
    *Vac Leak through TB shaft?
    *7 and 2 plug wires crossed?
    *some type of exhaust restriction, forcing the EGR valve open uncommanded?
    *bad pulse sensor in Dizzy?
    * Intake Manifold Gasket leak(shoot some propane onto the crankcase)?
    *Compression check?
    *have a buddy drive around while you watch a scanner to see if anything abnormal happens when it stumbles.
    *And, not for nuthin`, but i have been sold a TPS or 2 that were just thrown back on the shelf after someone else returned it as defective.......Murphy`s law, ya know?
    Good luck!
    1986 K10 Suburban
    350,TBI
    Jet AFPR
    TBI heads
    May 2007
    New engine, and the used parts (sensors and the like) Came from the old engine and were good. But thanks.
    Dec 2004
    Elkhart IN
    eh, it runs, just a little annoying... screw it, its getting 6mpg on a good day. i'll continue beating it into oblivion. as soon as i get my tax check back, i'm buying another truck and taking this one out of comission for a while.
    Jul 2008
    The 94 nearly stalls when you floor it but if you're 3/4 pedal or before, its fine.
    but man when you floor it just noses over and acts like its gonna die....
    Currently-
    May 2007
    It's been awhile since I've hooked the scanner up, I'm gonna have to do it and watch my BLMs. Just out of boredom and never having done it yet I got a full rebuild kit for my Throttle body, so I'm gonna play with it a little. I really gotta get working on a chip for this thing however.
