Thread: truck shut off while driving
Results 1 to 14 of 14
    Aug 2009
    Exeter RI
    i have a 1996 chevy 1500 5.7 vortec. i was driving and the truck just shut off on me. dos anyone no what the prob could be? the fule pump is still working it cranks over fine the radeo and light all work fine
    Aug 2008
    Jackson, Missouri
    Re: truck shut off while driving
    Make sure all your grounds are good and connections at the battery. When was the last time the fuel filter was changed?
    KILLBOY POWERHEAD
    Kenai, AK
    x2 on the grounds. neg bat cable can cause that if you hit a bump and the ground is loose.
    92xcsb350tbi
    its my money pit, what can i say
    Texans love Texas They are special people down there
    Aug 2009
    Exeter RI
    whats x2
    Piloting the Land Yacht Texsbluethunder's Avatar
    Alliston, Ontario, Canada
    Quote Originally Posted by sw45 View Post
    Yup, changed the intake gaskets one time and forgot to hook the ground back up on the back of the engine (firewall to trans dipstick mount) Took me a month to find out why it would intermitantly quit and not throw any codes.
    Alex
    '96 Chevy K1500HD ECLB, 385,000km and still goin strong...ish, Rebuilt 355 w/4L60e on its last legs
    '07 Pontiac G5, Wifes Blurple commuter, 97,000km
    78/80/93 GMC in many pieces and places waiting for time and effort.
    Apr 2003
    Ft.Lauderdale, Fl.
    Quote Originally Posted by 1998silverado69 View Post
    Is your fuel pump the original? Was the pigtail wiring harness replaced, that plugs into the top of the new fuel pump, if it is a new(er) pump? VERY important.
    Aug 2009
    Exeter RI
    Hey guys i replaced the fuel filter today, and i started it up by pouring gas into the throttle body and it fired up for a couple seconds and then it back fired and shut off, i got the air out of the shratter valve and it still does not start...
    Aug 2008
    Provo, UT
    This happened to my truck too, mines a 97. I thought it was something complicated but turns out the negative battery cable terminal connection was a lil loose, you have to tighten that thing hard, if u can even move it a millimeter it will still shut off on you somewhere. Mine has the side terminals dunno about yours but I would check that like other people said too.
    I've heard a few other issues that may ahve caused this
    Ground at the fuel tank
    dist cap cracked.
    Alex
    Registered User SpeedDevil's Avatar
    St. Louis
    side post suck. just converted mine to top post. If it starts by pouring gas down its throat...then perhaps fuel pump? Get a fuel pressure tester at autozone, prime the pump and see what psi is. Think you need 58 psi to start it.
    96 extended cab z71, 350 Vortec, 4x4, 4l60-E, 3.42, G80
    Dec 2009
    Over Yonder
    My '96 cut off on me like that once. I tried to restart and it rolled over fine, electronics worked and all that, but no start. The motor wasn't getting fuel thanks to a bad fuel pump.
    Jan 2010
    Vermont
    Hey silverado69,I just had the same exact thing happen to me today. This is after already replacing my distributor, new ac delco plugs, new air filter, cleaning the mass airflow sensor, new fuel filter and checking fuel pressure. All this was done for a lousy running engine. This seemed to fixed that problem, except it was then running with an occasional miss, until today, stopped running after on the road for at least 30 minutes. Starter fluid down the intake and a backfire. Fuel press good, now they are saying I probably need a new intake, bad injectors.(again one plug was all fowled up) Hope this helps some and if you get yours to run let me know what you did.
    Thanks,
    -Mike
    Registered User K1500Tech's Avatar
    Jun 2007
    I know a bad ignition module will cause a truck to stop running while your driving.
    Katzkin leather interior, 2" CCM Off road leveling kit, Ranch Hand grill guard, and Ranch Hand rear bumper.
    Apr 2003
    Ft.Lauderdale, Fl.
    Did you say you put a fuel pressure gauge on it yet? If not, start there. I believe you need a minimum of 50 psi. If you have 47 psi, it will not start.
