Thread: how many bolts hold the tranny to the motor?
Results 1 to 13 of 13
    Aug 2009
    michigan
    Exclamation how many bolts hold the tranny to the motor?
    how many bolts are there from the tranny to the motor in my 96? how hard are they to get to?
    ALL IN BALLS OUT wp silverado's Avatar
    Nov 2007
    savage md
    Re: how many bolts hold the tranny to the motor?
    they arent bad at all, iirc its 6 bellhousing bolts
    700r4
    4l60e
    King, NC
    Just replaced my 4L60 which was bolted to a 350. It had 6 bolts. The top two are a little difficult and you will need around 2 feet of extensions I have heard that a 4 ft extension will make it easier but I didn't have one or enough. Hope this helps. I used air tools which was a HUGE help in the tight space.
    Jun 2009
    NE Arkansas
    6 bellhousing bolt and 3 torque converter bolts
    1993 Chevy Suburban K1500 5.7L
    Valley, AL
    yup have 6 bolts. The 2 on top are little harder to get to. I have best luck getting them out with a 20 inch extension fitted to a 6 inch wobble extension and a deep well socket. Have fun
    93 Chevy C1500, Blue/Silver, LB, 5.7L, RV Cam, 4l60e, Vette Servo, 31x10.50x15 Michelin MTX M/S, 94 Grille, Cystal Clear Lights, K&N, Flowmaster Duals, High flow cat, MSD Coil, Jet TB Spacer, Jet Stage 1 chip, Jet 180 thermostat
    :fsc:
    Aug 2009
    I use a swivel socket and a long extension.
    May 2009
    Dallas
    I hope it will be easier after I put in the 3" body lift...
    Aug 2009
    michigan
    Thanks guys, I was only able to get the bottom bolts on each side, I had my deep well socket with a 9in extension then a swivel and a 10in extension on the end of that. I had plenty of room but couldnt get the bolt off. I was using my mac impact with 150psi, but im thinking it was the swivel extension that was taking most of that punch and not breaking the bolt loose. Should I try a flex extension? or will it just snap with the force of an impact?
    Thank you guys for the help!
    Aug 2009
    Use a swivel socket that is impact rated. It is shorter than a socket plus the swivel.
    http://www.harborfreight.com/cpi/cta...emnumber=40985
    Wisconsin
    Does anybody know the size of these bolts off-hand?
    Registered User Patrck's Avatar
    Los Alamos, NM
    Quote Originally Posted by pitracer View Post
    3/8X16 with 9/16" head.
    One of the few non metric bolts..
    '01 2500 6.0 K&N, Flowmaster
    Wisconsin
    Thanks a million. When pulling the engine my buddy was under the truck for that part. I guess he didn't want to keep track of 'em after he removed them. Should I just buy the highest grade I can find?
    Los Alamos, NM
    Grade 5 will do.
