Thread: Driving without front driveshaft?
Results 1 to 11 of 11
    Jan 2010
    latham ny
    hey guys the front seal on my transfercase is leaking. so i pulled the driveshaft out but cant break the nut on the yoke free. so i hit it with pb parts blaster and am gonna let it soak. my question is
    can i still drive the truck without the front driveshaft in??? i plan on trying the nut again tomarrow maybe with a little heat but want it to soak good over night in parts blaster. but i still need to get to school and work tomaarrow so im asking to see if i can still drive it...
    thanks guys
    clint
    Jan 2005
    northern KY
    Re: Driving without front driveshaft?
    yupp, driving without the front shaft should not be an issue.
    '89 K5 trail rig
    SE Michigan
    as long as it's not a a4wd/awd truck, you will be fine, a little more risk with an a4wd truck, but still ok, but don't consider it in a awd truck
    2000 Silverado 6.0 4L80E 2wd
    Registered User nitrouskid2601's Avatar
    fairfield illinois 62837
    it wont hurt a thing, i drove mine for a week with no front driveshaft when i had the differential out.
    03 1500hd ccsb 6.0 15.4mpg
    Jan 2010
    latham ny
    yea sorry guys i shoulda said what kinda truck it is. i just went on a week snowmobiling trip rode allmost 1000 miles in 5 days. im beat. and my sled broke today. and i came home to a broken truck and just didnt want to do anything.
    its a 97 k2500 5.7 4l80e.
    i thought it would be ok, but just wanted to make sure.
    The Terminator blackknight's Avatar
    May 2008
    Chicago Area
    been driving mine for a week or so without the front shaft in. no probs. shaft is getting new u-joints and will be installed tomorrow.
    Back in a truck!
    Current: 2014 GMC Sierra Z71 All Terrain
    Past: 2002 Silverado|5.3|RCX|Cognito|Blackbear
    Completed:HID TSX Projector Retrofit
    Jan 2010
    latham ny
    ok cool. i dont know if ill even be able to get this nut off. i tried the impact gun on it.... just short blips to try and loosen it up (didnt hold it long, wasent sure if it would mess up the t-case) and i tried a 3/4 inch breaker bar, nothing. pb parts blaster is some amazing stuff but that nut is tight!!!!!
    Jan 2005
    northern KY
    mix a 50/50 mix of acetone and tranny fluid in a spray bottle. it is a great penatrating oil,
    '89 K5 trail rig
    Nov 2009
    Canada
    Quote Originally Posted by blackknight View Post
    been driving mine for a week or so without the front shaft in. i no probs. shaft is getting new u-joints and will be installed tomorrow.
    Does your truck have the push button 4X4 transfer case with the auto 4x4 option.? I have the auto 4x4 transfer case and was thinking of pulling the drive shaft to troubleshoot a vibration problem.(2000, 1500)
    Dec 2009
    Logan WV
    is it the big flange/yoke nut like 1-1/4 inch size? If so I always use an impact and zap it off, I had to regear my monte ss and that's what I used since the thing would turn otherwise, a breaker bar wouldn't work with it turning, tried to make the car move.
    May 2008
    Chicago Area
    Quote Originally Posted by Rampage2 View Post
    Yea push button with auto, 2hi, 4hi, 4lo.
    before you pull the shaft, have your tires balanced, check your pitman and idler arm, check your bearings, balljoints tie rods. etc. common things.
    but the front shaft is relatively easy to remove.
    Back in a truck!
