Thread: Tall deck or short deck 454
Results 1 to 12 of 12
    89Chevy
    Jun 2009
    Waycross, GA
    I have a big block 454 engine, the casting numbers are: 14015445, what I'm trying to do is find out of the engine is a tall deck or short deck.
    Everywhere I have looked just lets me know what year it is.
    http://img188.imageshack.us/img188/6902/signhx.jpg
    Sep 2006
    Greenleaf, Wisconsin
    Re: Tall deck or short deck 454
    I don't believe the 454 came in a tall deck... someone may prove me wrong though.
    I'm pretty sure just the 427 and 366 came in the tall deck variety. That being said tho you could make one from a 427 if that's what your after
    '88 Rc/Sb - Parting out/selling everything... - Build Thread
    '72 Oldsmobile Cutlass - in the planning stages
    In the market for a NNBS
    73-98 trucks for life...
    Sep 2006
    Mesa AZ
    Its an original 454 then its a short deck.
    78 c10, shortbed/stepside: 5/5" drop, muncie M20, 388 stroker. Playtoy and first vehicle.
    98 gmc x-cab: 5.7L, 17"s, 5/6" drop, flowmaster,K&N, air ride helper bags, kicker sterio.
    06 Honda CBR600F4i: freakin rocket ship
    ----------Disclaimer: I can't spell-----------
    Welds Like Robot 907 Chevy's Avatar
    Aug 2009
    Anchorage,AK
    Do you know what this motor came out of?All big blocks that came in trucks were tall deck I think.
    Big blocks in cars had standard deck heighth.
    DD: 1989 Taurus SHO
    Project:1995 ECSB,Auto-5 speed manual conversion,Vortec 357,LT4 Hotcam
    Jan 2010
    It's very easy to tell just by looking at the front of the block. If it's a short deck block the top water pump bolt holes are very close to the deck on the block. If it's a tall deck block there is a little space between the top water pump bolt holes and the deck.
    If you're unsure what it should look like just find a motor (in or out of a car) that you know is either a tall or short deck and compare it to the one you've got.
    Once you've seen the difference you can ID a tall or short deck BBC with a quick glance at the front of the block.
    Edit:
    I did a quick picture search and came up with these two pics (not the best pics, but you get the idea). Look at the water pump bolt holes on these two blocks...
    Short deck block (9.8" deck)...
    Tall deck block (10.2" deck)...
    Dec 2004
    Elkhart IN
    Quote Originally Posted by 907 Chevy View Post
    all big blocks in light trucks 10/20/30 1500/2500/3500, etc. were short decks. the tall deck blocks were available in only medium duty trucks, and only available in 366ci and 427ci versions. no tall deck 454 was ever offered.
    Aug 2009
    Anchorage,AK
    http://www.roadsters.com/bbc/#blocks
    At the bottom of the list.It's a short deck.
    Looks like a couple 454 castings were offered with tall decks.
    Is that good enough for you,Greasedog?Or would you prefer to settle this with a dance-off?
    DD: 1989 Taurus SHO
    Woodstock Ontario Canada
    The GEN VII 8.1(496) is a tall deck block, as is the 572 crate engine.
    peace
    PAuly
    Dec 2004
    Elkhart IN
    dance if you like, my sources, which are in my experiences VERY accurate, and widely known and used say that the TWO casting numbers you're pointing out are a 427 tall deck block, and a short deck 454...
    http://www.mortec.com/bbc.htm
    Aug 2009
    Anchorage,AK
    True,the web page could be inaccurate and I may have just pulled a dubya,but I have no way of knowing either way.Dance-off it is...
    DD: 1989 Taurus SHO
    89Chevy
    Jun 2009
    Waycross, GA
    It came out a 1-ton dually, I don't remember what year it is because the people let us have the motor. Were building it for a rail dragster I have.
    Jan 2010
    It doesn't matter what you think it came out of, what year it is, or what you think the displacement is, if you want to know if it's a tall deck or short deck block see post number 5. End of story. I've been a big block Chevy fan for a very long time. The top water pump bolt holes will tell you if it's a tall deck block or short deck block in a heartbeat. All you have to do is look at it, it's very simple.
    Edit: If you are still unsure, post a pic of the front of your block with the water pump off.
