Thread: New BRAKES getting HOT need HELP!!!
Results 1 to 10 of 10
    Jun 2008
    the boro
    I just replaced the pads and rotors on my 00 Chevy 1500 Z71 and now my brakes are getting hot as hell.
    I never took the brake lines off or loosened any of those bolts. I just pushed the caliper cylinders back in with a C-clamp, put the new pads and rotors on, threw the wheels on and was done.
    Anybody know what is causing them to get so hot?? What can I do to fix it??
    Thanks
    Seth
    Bangor, ME
    Re: New BRAKES getting HOT need HELP!!!
    If you bought aftermarket "lifetime" pads, maybe they're too thick and they're dragging a little?
    If that's the case, they'll probably wear down, but you'll want to be careful. If they get too hot, you can warp your rotors.
    Cape Cod, MA
    Which wheels specifically are getting hot? The rear disc equipped models very often exhibit frozen rear calipers after a brake job. The fronts could do it too but it's the rears that are notorious for sticking.
    The cause is the harsh life those rear calipers live. As the pads wear and the pistons extend out, the exposed parts of the piston can become corroded and when you put new pads in and push the pistons back to their starting point, they don't want to move so nicely and the result is a constant slight drag of the pads on the rotors that lead to really hot rear brakes. The simple fix is to replace the rear calipers with some reman'd calipers. I had to replace both of my rears due to this and I know friends who have had to do that same thing. This sort of topic also pops up on here about once a week so I know it's not a rare issue that only I had to struggle with. Hope this helps point you in the right direction.
    Feb 2008
    New Hampshire
    Did you spray down the rotors with brake kleen? There's usually a coat of anti rusting stuff on them when you buy them.
    St. Louis
    How did the new pads fit in the caliper? I have had aftermarket pads that didn't fit the recesses in the caliper very well. They should be a drop in fit and often aren't.
    The last set I put on, they fit so tight that they bound up and wouldn't actually move to get 100 percent contact with the rotor. Had to file the end flanges so that they could be free to move in the caliper. Problem solved.
    Bob
    Mobile,AL.
    yes like tweaks mentioned,you should replace calipers if you truck has been through many brake pad changes,at least buy new pins,bolts?you know, them things the calipers slide on.Also if drums in rear get new springs,hardware,10 years is a lot of work for them brake parts.
    Kentucky
    What do you mean by "they are getting hot?" Can you smell them or something?
    Lake Conroe Texas
    Quote Originally Posted by Stratosman View Post
    Same question from me. What makes you think they are getting TOO hot? Brakes get really hot by design, it's the nature of friction....and by hot I mean you will burn your finger if you touch the brake parts after driving.
    Jun 2008
    the boro
    Thanks for all the replies. The brakes seem to fit fine.
    The rear brakes were so hot after I put the rotors and pads on that they were smoking when I got back to the house after a 1.5 mile test drive.
    TWEAKS Im definetly leaning toward getting new calipers I might try to bleed the old ones a bit to see if that helps before I do so but I dont even know if that will be worth the time.
    Lanark, Ontario
    Bleeding will not solve anything if they are dragging. How well did you lube the caliper pins, how freely is you caliper floating?
