Thread: Fluid specs for 2001 Chevrolet Suburban?
Results 1 to 3 of 3
    Jul 2006
    Tracy, CA
    I have a 2001 Chevy 5.3 L Suburban ( 4x4)
    I can't seem to find my manual book.
    Do you how much fluids does my Suburban take on the foloowing
    Rear End differential gear oil 75W90? Goin going use Royal Purple since no need of limited slip additive.
    Automatic Transmission fluid?
    Steering Fluid ?
    Thanks
    Nov 2009
    Canadia!
    Re: Fluid specs for 2001 Chevrolet Suburban?
    No clue on the PS fluid, a bottle maybe? haha
    and my computer is telling me 7.3 Liters initial fill for your 4L80-E tranny
    4L60-E (DRY) fill = 10.6 L
    4L80-E (DRY) fill = 12.8 L
    Rear Diff = 2.6L
    Transfer case:
    NVG 149 = 2.3L
    NVG 236 / 246 = 1.9L
    NVG 261 / 263 = 1.9L
    Front Diff = 1.7L
    2001 Chevy Silverado Z71
    Toy hauler
    Quote Originally Posted by josh25 View Post
    Some guys just like the look and that is fine I enjoy the designs and the appearance of a nice rod.
    MI/AZ
    CHEVROLET TRUCKS 5.3L 8-cyl Engine Code [T]
    CAPACITIES
    Engine, with filter..........6.0 quarts[1]
    Cooling System, W/ FR & RR AC Initial Fill..........16.0 quarts
    Cooling System, W/ Front AC Initial Fill..........14.0 quarts
    Automatic Transmission, 4L60-E Initial Fill..........5.0 quarts
    Automatic Transmission, 4L80E Initial Fill......7.7 quarts
    Automatic Transmission, Total Fill
    4 speed 4L60-E..........11.0 quarts
    Differential, with 8.25 ring gear Front..........3.0 pints
    Differential, with 9.25 ring gear Front..........3.2 pints
    Differential, with 10.50 ring gear Rear..........5.5 pints
    Differential, with 11.50 ring gear Rear..........7.6 pints
    Differential, with 8.60 ring gear Rear..........4.2 pints
    Differential, with 9.50 ring gear Rear..........5.5 pints
    Transfer Case,NP8..........4.0 pints
    Transfer Case,NR3/NR4..........3.0 pints
    Transfer Case,NVG 246-NP8..........4.0 pints
    Transfer Case,NVG 261-NP2..........4.0 pints
    Transfer Case,NVG 263-NP1..........4.0 pints
    Dont forget the transfercase requires the "Blue" fluid from the GM dealer.
