Thread: One inch (?) tube going from air cleaner to exhaust manifold...
Results 1 to 9 of 9
    I lie about my mpg's. 14GDHPs4ME's Avatar
    Dec 2009
    Reno, NV
    Question One inch (?) tube going from air cleaner to exhaust manifold...
    I was poking around under the hood today and noticed there was a metallic, one-inch (maybe 1 1/4) diameter hose going from my intake (just before the air cleaner) to the exhaust manifold on the passenger side. More curiously, it was undone on the exhaust manifold end, and I have no idea how long it's been that way.
    What is this? What does it do? How important is it that it is hooked up? What happens if it's unplugged?
    Sorry I'm still new at this, and the search didn't help much.
    1992 K2500 LD 4x4, 5.7, 700r4, 3.73 14-bolt, G80, Cleaner than sh!t.
    2001 Tahoe LS 4x4(the wife's), 5.3, 3.73, G80, third-row seats.
    Bangor, ME
    Re: One inch (?) tube going from air cleaner to exhaust manifold...
    It's to heat up intake air for cold starts with warm exhaust gases.
    You can chuck it and not worry about it. I don't think I've seen an older vehicle with one intact.
    Registered User machinist09's Avatar
    Cow-town, Alberta, Canada
    seriously; chuck it. why would you want warm air going in?
    1999 Chevrolet K2500, Crew Cab, Short Box, 4L80E, 454 ci, 3.73 rear 14b FF 10.5"
    Working on my own custom tune with EFI Live.
    Aug 2008
    New Hampshire
    It is called a "chimney" and is part of the Thermac system. As noted above, the Thermac system was designed to deliver warm combustion air from a molded sheet steel collector that wrappped around the exhaust manifold. There is no actual exhaust gas in that riser (chimney) just fresh, preheated air.
    This warm air is available to the carburetor (via a vacuum actuated flap valve on the underside of the snorkel) during cold start conditions. As the engine warms, a sensor (usually screwed into the thermostat housing) gradually dumps the full vacuum down to the point where the flap in the intake snorkel has shifted to admit only cool air.
    JoshTheCanadian
    I love in Canada, Gets down to -35C here, I got rid off all of that Thermac stuff, truck starts EVERY time, even when not plugged in.
    Lake Conroe Texas
    It's called a preheater hose and don't discard it unless you know local emissions inspections won't require it to be present.
    Dec 2009
    Reno, NV
    I guess I'll just leave it disconnected (maybe plug it in before I get it smogged) and keep it in mind if I ever have cold start problems. Thanks for the information, guys.
    St. Paul, MN
    My 84 with a 2 barrel carb starts fine in below 0 weather with no icing of the throttle blades after i got rid of the tube. You will be fine to remove the tube.
    Nov 2009
    Canada
    I had a jeep CJ-7 with the six cylinder in it. It had the preheat disconnected on it. In the extreme cold the carb kept icing up and it didn't run worth chit.Might of been other factors involved but that was my result.
