Thread: difference between 2wd and 4wd rear ends??? 88-84 OBS
Results 1 to 6 of 6
    Southwest, Georgia
    difference between 2wd and 4wd rear ends??? 88-94 OBS
    Guys I have a 91 K1500, and the rearend is going out. I have a good rear end from a friends 94 C1500. Can I pull my 6 lug axles and put them in the 2wd rear end and bolt it in or is there a difference dimensionally?
    Redneck Hillbilly Fix 'er Redliner Raw's Avatar
    Jun 2009
    Guelph, Ontario, Canada
    Re: difference between 2wd and 4wd rear ends??? 88-94 OBS
    Quote Originally Posted by Hammack View Post
    I think spring perch width is an issue. Gotta watch gears too. I'm not sure if the axle splines are the same.
    94 C1500 RCLB, 305/5LM60, 14 BFF, 3500 springs, 4.10's, 265/75LT16's, 235/85LT16's, 4 Wheel Disc conversion
    Quote Originally Posted by WildChevys View Post
    stop riding kirk's d i c k without a helmet and go to bed.
    Bangor, ME
    Re: difference between 2wd and 4wd rear ends??? 88-84 OBS
    The 2wd housings are 3" narrower. I think the spring perches and the shock mounts may still line up. Axle spline count should be the same (30). Your 4wd axles won't work in a 2wd housing due to the width though.
    Any 4wd axle from 88-98 will bolt right in. Might be a good time to look for a 14 bolt SF.
    2014 Silverado 1500 Z71, leveling kit, SOLD 8/2016
    2016 Silverado 1500 Z71, 6.2 V8, all stock
    Jun 2009
    Quote Originally Posted by daved931 View Post
    So the pumpkin itself is wider in a 4wd? That's weird, dunno what that would accomplish...
    Bangor, ME
    The pumpkin is not wider, the axle tubes are longer. It is to maintain track width as the front track is wider to fit the CV shafts.
    Jun 2009
    that makes sense. Never thought of that before.
