Thread: biggest widest tires I can put on 2003 chevy 1500 z71 help!!
Results 1 to 4 of 4
    Apr 2010
    Fulton, MS
    what is the biggest widest tires I can put on my stock chevy 1500 z71 extended cab? im putting them on stock 16 alminum wheels. also, my TB is not cranked up none. I want the tires to be wide as they can be but without rudding the fender any. I want them to stick out away from my truck a good bit. or what is the biggest and widest tires in mickey thompson I can put on my truck? Thanks
    JoshTheCanadian
    Re: biggest widest tires I can put on 2003 chevy 1500 z71 help!!
    315/75/16?
    LM7 Outlawz2004's Avatar
    Louisiana
    Quote Originally Posted by JoshTheCanadian View Post
    315/75/16?
    not at stock height without rubbing. 285s will rub at stock height on hard turns. Crank the bars and you should be able to fit the 315s without rubbing, but on a stock wheel dont expect them to really stick out. You need a different offset wheel to really make them stick out, and if you do that plan on some ball joints being worn as well with the larger tires.
    Nov 2009
    Wake Forest NC
    They arent gonna stick out tooo much with the stock wheels
    00 Silverado , 5.3L, No cats or mufflers dumped over axle, little bit of thumpage, 3'' BL, Cranked, 285's, 35w 6000k lows, 55w 8000k highs, 4high mod.
