Thread: best TBI tuner?
Results 1 to 20 of 36
    Jan 2010
    pflugerville Tx
    best TBI tuner?
    dose anyone know i good tuner for TBI computers besides brian at TBI chips? i have a vortec heads and a LT4 hot cam and am about to buy a wynjammer for it and need it tuned any info will help. thannk you.
    1993 chevy 350 vortec engine with GM performance intake to match the heads. MSD 6Al,blaster coil, 8.5mm wires. custom hypertech tune chip, long tubes, build trany shift kit, billet servo. E fan's. slammed with a 7',8' drop. coming soon....cam and valve train up grade and single stage of nitrous.
    Bizzybone485
    Dec 2004
    Ocala, Florida, United States
    Re: best TBI tuner?
    I would buy an ebl flash and tune learn to tune it yourself. Thats my route next when the money comes around. I would probably also spend the money on a procharger or whipple if you want it to last cause they are kind of a hit or miss from what i understand. Although the guy that sells them is pretty helpful from what people say.
    91' RCSB Red Silverado on a 4/6 with Custom 355 ( .449 .456 212 218 112), Tbi mods, 65lb inj. /flowtech headers, 2.5 40-flowmaster,Tuned W/EBL Flash,Custom Bench http://www.cardomain.com/ride/2059169?poll_action=view
    Registered User flyinbrian's Avatar
    Aug 2003
    Central Virginia
    Re: best TBI tuner?
    I came in to post the above.
    Get an EBL and never look back. ------->http://dynamicefi.com
    1993 K2500 Suburban. 454 poked and stroked to 496. Comp Cam roller valvetrain, JimD(454ss.com) bored TBI, Thorley headers, Edelbrock TBI intake ported and flowed. Innovate WBO2, TunerPro RT, Ostrich, Burn1.*Now running a Dynamic EFI EBL with a '7060 piggybacked to run the 4L80E.*
    Pacific NW
    Re: best TBI tuner?
    Agreeing with the above about the EBL for your engine! It's only transmission control is TCC, just to be sure you know this.
    89 K3500 RCLB- Fat Snarling RAT..Scat/Eagle/Crower/Crane/Edelbrock/MSD..TBI/EBL/TH400/Dana 60
    Bizzybone485
    Dec 2004
    Re: best TBI tuner?
    hey flyinbrian, how did that EBL and tuning help you with mpg's overall? Are you running 87,89,91, or 93 octane with it? Thanks!
    Jan 2010
    PA
    Re: best TBI tuner?
    So from what I've read on the EBL site, the EBL will 'learn' and basically program the tune to your vehicle?
    Bizzybone485
    Dec 2004
    Re: best TBI tuner?
    Thats pretty much what i have learned and understood. The only thing is that the tune is only as good as the reading from the 02 therefore you need a wide-band O2 sensor to start doing WOT tunes. From my understanding, its the only way to go with TBI! I'm surprised it hasn't flooded this site yet while ive been missing in action trying to finish up school.
    Registered User 94Blazer383's Avatar
    Sep 2006
    Bardstown, KY
    Re: best TBI tuner?
    That all depends on what year TBI you are trying to tune. 94-95 you can not use EBL.
    HAULIN A$$,AND SUCKIN GAS 350CHEVYROB's Avatar
    Nov 2009
    Kalamazoo.Michigan
    Re: best TBI tuner?
    Quote Originally Posted by 94Blazer383 View Post
    why is that i'm just curious because i have a 95 yukon
    95 GMC Yukon 1500 4X4
    Oct 2005
    Kentucky
    Re: best TBI tuner?
    Quote Originally Posted by 350CHEVYROB View Post
    I'm guessing it's b/c of the 4L60E tranny that the computer controls as well and EBL doesn't do that..........
    Nov 2009
    Kalamazoo.Michigan
    Re: best TBI tuner?
    Quote Originally Posted by 93ChevyTBI View Post
    i see.in your sig you have a 2" TB i am going to get one this week and i wanted to get some feedback on how good it works .do you like the why it performs and what vac ports still work and if you can tell me were you got yours ..thanks rob
    P.S don't mean to thread jack .just wanted to get some feedback on it ..
    Oct 2005
    Kentucky
    Re: best TBI tuner?
    I have a 2" Holley base with the stock 350 pod on top, stock injectors with high volume pump and raise fuel pressure with no issues. I think I'm using 3 ports (MAP in rear, PCV in front, and I don't remember what else is in front) and the rest are plugged off. I don't have any problems with running out of air or fuel at WOT. Bought the 2" base off Ebay from Affordable Fuel Injection
    Nov 2009
    Kalamazoo.Michigan
    Re: best TBI tuner?
    kool thanks .I've heard bad things about the holley tb base but that is hear say .right now i still have the stock tb on my 383 vortec right now.it ok but it will lose power after 3000rpm and stop pullin hard but low rpm is alright .but i can't run my 80lb injectors with the stock tb because it will foul out the plugs .i have a compcam 304.. 210/220.. 500/510 lift @114lsa .dose yours pull pretty good throw the entire rpm range .and did you feel a big difference from the stocker
    Sep 2006
    Bardstown, KY
    Re: best TBI tuner?
    I have the 350 TBI bored out to 2". I bought it from a guy off Ebay as well. I also have 454 80 lbs/hr injectors to feed the 383. You will need a tune after you install that.
    And yes 94-95 "PCM" controls the 4L60E tranny.
    Oct 2005
    Kentucky
    Re: best TBI tuner?
    Mine is a 93 and is PCM-controlled
    Nov 2009
    Kalamazoo.Michigan
    Re: best TBI tuner?
    well i already have a tune for it .its tuned for the bigger tb and 80ld injectors just don't have it in yet .I'm getting a stock tbi bored to 50mm 2" bore
    Nov 2009
    Kalamazoo.Michigan
    Re: best TBI tuner?
    did you like the one you got off ebay .and what size cam are you runnin
    Oct 2005
    Kentucky
    Re: best TBI tuner?
    kool thanks .I've heard bad things about the holley tb base but that is hear say .right now i still have the stock tb on my 383 vortec right now.it ok but it will lose power after 3000rpm and stop pullin hard but low rpm is alright .but i can't run my 80lb injectors with the stock tb because it will fool out the plugs .i have a compcam 304.. 210/220.. 500/510 lift @114lsa .dose yours pull pretty good throw the entire rpm range .and did you feel a big difference from the stocker
    No EFFIN comparison to how it pulls vs the stocker....none at all. I could cruise in it stock but didn't have to get-go for passing or for towing much. It puts a smile on my face every time I just give it half throttle. It pulls hard throughout full rpm range.
    Maybe...I could give a LITTLE credit to my tuner too though. He may have helped it SOME...not much...a little.
    .....tune made a world of difference, really it did. You can have the best damn parts money can buy but if it's not tuned to work together you won't be seeing the full benefit.
    Oct 2005
    Kentucky
    Re: best TBI tuner?
    he's running the Lunati Voodoo 60101
    Nov 2009
    Kalamazoo.Michigan
    Re: best TBI tuner?
    right i head ya on the tune my tune is for Brian at tbichips witch works great but I'm not gettin the full power that the chip is tuned for .yea the tb is what i really need it kinda piss me off a lil when i floor it and it really don't do much ..................
