Thread: 700r4 shifts hard
Results 1 to 3 of 3
    Jan 2009
    Iowa
    700r4 shifts hard
    i have a 1992 chevy silverado with a 5.7l it has a 700r4 tranny and recently it has started to shift hard from 1st to 2nd gear..i no there is alot of solenoids and control modules to this tranny but i have no idea what they do and where they are located. someone please help
    Built, not bought. Bad Bowtie 91's Avatar
    Augusta Ga.
    Re: 700r4 shifts hard
    The 700R4 is controlled by the TV cable that hooks to the throttle arm on the TBI unit. Other than that, there's no solenoids or modules that control shift points.
    Think of the 700R4 as a TH350 with overdrive
    The TV cable controls shift points and line pressure in the transmission, it probably came loose or might have broke the little clip off that holds it to the throttle arm.
    It might need adjusting also, it's easy and only takes minutes.
    Here's a link with instructions on how to adjust the TV cable.
    TV cable adjustment instructions < click that link.
    91 ECSB, 305 bored .30 over, Flat top pistons, Summit Racing 272/282 cam, Holley carb, Edelbrock intake, Accel HEI dizzy, 801 heads, 700R4, 3.42's open.
    Nov 2008
    Southern MD
    The TV plunger in the valve body is a known issue with the 700R4, they can stick from wear and result in over firm part throttle shifts even if the TV cable is adjusted properly. The shift kits come with a special spring you add that makes the TV plunger return without sticking, so if your TV is adjusted properly you may have valve body wear issues.
    1988 K1500. TPI conversion (mass air), self burned prom, LT1 roller cam, rebuilt and ported 083 heads, headers, 3" single exhaust
    1999 C1500. 5.7 vortec swap. Flat top pistons, balanced rotating assy, LT1 roller cam, GMPP Vortec heads, EFILive V2 tuner. 4" lift spindles 1.5" rear blocks.
