Thread: How many quarts of fluid is needed if i remove the pan on my silverado.
Results 1 to 20 of 32
    Registered User pontiac69's Avatar
    Jun 2010
    Pa
    How many quarts of Trans fluid is needed if i remove the pan on my silverado.
    Oh yea Transmission fluid. I want to drop the pan and change the fluid and filter on my 05 silverado 5.3 4x4. I posted this once before but nobody responded. I find it hard to believe nobody knows this or have done this before. The shop wants 288. That is rediculas.
    G-FORCE FinalBreath's Avatar
    Milwaukee, WI
    Re: How many quarts of fluid is needed if i remove the pan on my silverado.
    Usually around 5-6 quarts with removal of the pan.
    88 K1500 5.7 220K SOLD
    95 K2500 5.7 336k SOLD
    96 K2500 6.5 171K
    06 Trailblazer LTZ
    Jun 2010
    Pa
    any recomendations on type of fluid to buy.
    LM7 Outlawz2004's Avatar
    Louisiana
    your manual in the glove box will tell you this info.
    Kassy dixie_fl_angel's Avatar
    Florida
    i assume you need synthetic fluid since the shop is charging so much, that is a bit pricier then what we charge
    Since your replacing the filter as well your truck takes a little more fluid--more like 7 qts. If you were just dropping the pan it would be 5.
    DEXRON III
    Mundelein
    buy 7 and put in 5 and check the level...add as necesary and if you plan on keeping the truck or can stomach spending the money use royal purple otherwise mobil one is also very good and a lil cheaper
    Jun 2010
    Pa
    So Dextron 3 is what i should use. I know i have seen 2, 3 , 4 in the dextron. I looked in the manual and its not specific. i figured talk to the people with these trucks hence posting here.
    Registered User Patrck's Avatar
    Los Alamos, NM
    DexronIII (no T in dexron) is what it calls for, but you might consider using Dexron VI as it's an updated, higher quality fluid.
    GM put out a TSB (in 06 I think) saying to use Dexron VI in all previous III applications.
    '01 2500 6.0 K&N, Flowmaster
    Jun 2010
    Pa
    i will pick up 7 quarts this weekend if i have time of the dexron 4.
    thanks
    Registered User Z15's Avatar
    Aug 2008
    Michigan
    fyi
    There is no such thing as Dexron 4. Dexron III-E is what came in your truck but is obsolete. They skipped 4 and 5 and went right to Dexron VI which is the current standard and what you should use.
    Here is a link to a lookup for info on vehicle from 1980 up to 2010----> Auto and Light Truck Guide
    Example of what you can lookup.....
    CAPACITIES:
    Engine, with filter..........6.1 quarts [1]
    Cooling System, With AT Initial Fill..........15.3 quarts [2]
    Cooling System, With AT Initial Fill..........16.9 quarts [3]
    Automatic Transmission, 4L60-E Initial Fill..........5 quarts
    Automatic Transmission, Total Fill
    4 speed 4L60-E..........11.3 quarts
    Differential, With 10.50 RingGear Rear..........5.5 pints
    Differential, With 8.25 RingGear Front..........3 pints
    Differential, With 9.25 RingGear Front..........3.6 pints
    Differential, With 8.6 RingGear Rear..........4.3 pints
    Differential, With 9.50 RingGear Rear..........5.5 pints
    Differential, With 9.75 RingGear Rear..........6 pints
    Transfer Case, NVG 149-NP3..........4.5 pints
    Transfer Case, NVG 246-NP8..........4.1 pints
    Transfer Case, NVG 261-NP2..........4.1 pints
    Transfer Case, NVG 263-NP1..........4.1 pints
    [1] After refill check oil level.
    [2] With AC & Engine Driven cooling system.
    [3] With AC & Electric cooling fan system.
    TORQUES:
    Oil Drain Plug.....18 ft/lbs
    Transfer Case NVG263-NP1
    Fill Plug 15 ft/lbs
    Drain Plug 15 ft/lbs
    Transfer Case NVG261-NP2
    Fill Plug 15 ft/lbs
    Transfer Case NVG246-NP8
    Fill Plug 15 ft/lbs
    Transfer Case NVG149-NP3
    Fill Plug 15 ft/lbs
    Mike
    2010 GMC SLT SBEC Z71 All Terrain
    2009 Cadillac CTS4
    Jan 2010
    Ohio
    5 quarts put mine right on "full hot" after a drive cycle after dropping the pan and changing filter/gasket. and it has the deep pan also.
    2000 Silverado Z71 ECSB Stepside LT
    5.3L, 3.73, K&N CAI, Flowmaster muffler
    Registered User enine's Avatar
    Feb 2005
    OH
    NAPA told me 6 and 5 brought it up to the full mark.
    Anyone have pointers for getting the torx bolts out for the shift bracket, I couldn't get mine to come loose so I did a quick search and everyone said to bend it outward, gave just enough room to squeeze the pan out. I was looking under again and it looks like they may be right below the 4x4 lever so I may remove it and go down through the floor with an extension on an impact wrench and. I want to replace the torx with normal hex head so I can easily remove them next time.
    Getting the gasket on was a pain, its so tight of a squeeze it would get drug off the pan every time I tried to get the pan in place, I ended up getting the pan positioned and letting it sit on the exhaust then carefully sliding the gasket over the top.
    2004 Silverado ECSB 5.3L z71
    1979 Glastron HPV-160
    1991 Specialized Rockhopper
    2009 Giant Cypress DX
    Jan 2010
    Ohio
    the torx bolts were a pain but you can fit your arm around the driveshaft and exhaust to get to them. I used a small head 3/8 ratchet and torx socket to get them broke loose then just painstakingly loosened them with my fingers. I loosened the transfercase mounting bolts and jacked the case up just to get a few more inches clearance for the pan to slide in and out over the y pipe. Put a SMALL amount of silicone sealant on the pan itself before you lay your gasket on it. It will help greatly while getting the pan in place. I stress using a small amount because dried silicone can be detrimental to a transmission. I was working on my dads lift though which makes the whole process much easier.
    Maine
    Quote Originally Posted by dixie_fl_angel View Post
    DEXRON III
    Why would dropping the filter cause you to need more fluid?
    Aug 2008
    Michigan
    If you buy a quality trans filter/gasket the gasket will have 4 bolt holes in the corners that are slightly smaller which allows you to thread in 4 bolts to hold the gasket in place while installing the pan. Be careful using any sealant that could end up inside the transmission. There are very small fluid passages in the trans and any excess sealants can get up into the trans and cause future problems. There are several very good spray adhesives that are safe to use with a auto trans but do not overdue it.
    Mike
    2009 Cadillac CTS4
    Registered User Slipkorn34's Avatar
    May 2010
    Minnesota
    i dont know if youd need 2 more quarts (id get the 7 just in case though) but the filter holds oil just like the oil filter holds about a quart
    1969 Mercury Cougar XR7 - Temporarily sold
    1978 Chevy Scottsdale, 1956 Chevy Short Step Bed - Sold
    1996 Chevy k1500 - sold
    1990 chevy c1500
    Originally Posted by dhvaughan
    $75 would be ok if it didn't come with a new wife !
    I'd rather just have the toolbox and pay list price.
    Aug 2008
    Michigan
    Actually the internal GM tranny filter holds very little oil, maybe a few oz at most.
    Mike
    2009 Cadillac CTS4
    Maine
    Never seen an anti-drainback valve on a trans filter. They are always submerged, so there's no need for one.
    Feb 2005
    OH
    Quote Originally Posted by GM4ever98 View Post
    I can get the ratchet on them, just can't get them to come loose.
    Jun 2010
    Pa
    One more question.I have seen some responses about the difficulty of removing the pan. And some talking about a specific torx bit. Is teh torx bit used on the filter. The pan seems pretty accessible.
