Thread: A solution to the Chevy slip yoke clunk...
Results 1 to 20 of 30
    Oct 2009
    Louisiana
    The solution has been to remove the drive shaft and pack the slip yoke with grease. The grease removes volume (and acts as a 'cushion') and therefore provides resistance against the free travel of the slip yoke in and out of the transfer case. The problem is that it isn't a long term fix and has become a pain in the arse to remove the driveshaft to pack with grease every few months. So, in an effort to reduce the time and effort necessary to accomplish this task, these are the steps I took....
    Sorry for the quality of the pics...they were taken with my cell.
    First, I removed the drive shaft and drilled a 1/4" hole 1/2" from the slip yoke flange.
    Tapped the hole...1/4"x28
    And installed a grease fitting
    In turn, what used to take 30 minutes to accomplish can be done in less than two and with a grease gun as the only tool required.
    Also, I used the smallest grease fitting I could find to reduce or eliminate the possibility of throwing the driveshaft out of balance.
    I feel absolutely NO vibration at all speeds so I'm still balanced. I feel like the addition of weight is negligible when considering the
    amount of material I removed from drilling the hole in comparison to the weight of the grease fitting.
    Nov 2009
    AL
    Re: A solution to the Chevy slip yoke clunk...
    Mine came with a fitting on it already from the factory but good idea.
    CCLB dually, LS-1 Injectors, Airaid Intake, Magnaflow 2.5 dual in/out, Derale Cooling Tube Pan, B&W 24K super cooler[
    Registered User fuel583's Avatar
    Sep 2003
    New Jersey
    I was thinking of doing the same thing..... kinda getting tired of the clunking
    '95 2500 / 5.7 / 6" Superlift / 2" BL / 16x10 589s / 36" TSLs / (sold)
    '06 Silverado Z71 / 5.3HO / AFE Intake / Corsa Sport / Blackbear Tune
    Registered User Turkmod's Avatar
    Jul 2010
    Brandon, Manitoba
    did the same thing 3 years ago..... after taking out the ds the second time to grease it i decided to just drill and tap it our for a grease nipple.... 3 years and no issues!!!
    Midwest FSC Chapter!!
    Illinois
    hmmm i already need to grease mine pretty bad....might have to get me a tap and some grease fittings so i can take care of it this weekend
    97 z71,3" body lift, tow mirrors, cranked and AAL, 35" KM2's, 4.56 gears w/lockright, 6k HID's, strobes/lightbar/leds
    06 2500hd 6.0 gasser, 4" lift, 37" Toyos on 20" rockstars, 20" lightbar behind grill, colormatching in progress
    Dec 2007
    Oakwood GA
    Man that is great. I'm getting tired of hearing that sound. Perfect timing as well since I have to remove mine to pull the trans for repair.
    Mike,
    1997 Chevy Z71 5.7L/Edelbrock Ceramic Shorties/Magnaflow Cats/Banks Stinger Exhaust/MSD Coil/Accel Cap,Rotor,Wires/K&N Filter/TB restrictor removed/Vette servo
    Sep 2006
    Tennessee
    Don't they also make a "slip yoke eliminator" for the T case to resolve this issue?
    Illinois
    Quote Originally Posted by masintenn View Post
    i do believe that they do but it requires a new driveshaft i believe and it is quite expensive too
    Sep 2003
    New Jersey
    Anyone else do this and not have any vibe problems? Is there a possibility that if you pumped too much grease it could get into the transfer case?
    Jul 2010
    Brandon, Manitoba
    i did this "mod" more like and improvement to me.... i dont have a vibe at all and 3 years strong. and i dont know about the grease getting into the transfercase but i only throw a couple of pumps into it at a time and i only grease it now maybe 1 every 5 months or so with Lukes tacky grease. its real sticky stuff.
    Oct 2009
    Louisiana
    Yeah, you have to pump it several times initially to fill the cavity with grease. I would suspect after the initial fill of grease, you should only have to add a couple pumps every few months as needed. Also, isn't there a seal on the transfer case to prevent dirt and debree from entering? If so, shouldn't this also prevent grease from entering?
    Oct 2009
    Louisiana
    Quote Originally Posted by fuel583 View Post
    If you worry about vibe, you could drill thru the slip yoke and put a grease fitting on both sides (180 degrees apart) which would eliminate the possibility of vibration.
    Registered User crushor's Avatar
    Jun 2010
    midwest
    I would have to agree with the thought of the grease fittings on the yoke. I bought my Burban with this noise, and the local shop has directed me to purchase a new shaft. I prefer the $10.00 fix method instead. Worst case scenario, you will also want to grease u-joints and other points while underneath. Great idea.
    '99 Chevy Burban, 2007 Ford F-250 Harley-Davidson edition Powerstroke, 1988 Ford TBird 5.0L, 2012 Sure-Trac 18' Dovetail Car Hauler, 1987 Mustang 5.0L.
    Sep 2003
    New Jersey
    Quote Originally Posted by Greyhound View Post
    Yea thats true, I didnt think of that....
    Yea there is a seal, I was just thinking more like if you pumped excess grease would it bleed out onto the ground or would the pressure force it past the seal and into the t case...
    Supporting Member
    May 2007
    North Dakota
    I might consider this, not a bad idea.
    '00 Chevy RCSS 4x4/Z71 FOR SALE!!! - '98 Harley-Davidson Sportster 883 - Scroogle
    Quote Originally Posted by neonclown View Post
    I'm not sure you can bash ignorant people by being ignorant, but A for effort.
    Jun 2009
    S. Vermont
    So that's what clunks even in 2WD when the rear tires hit an incline at the same time? It does it at the bottom of a hill at an intersection near where I live every morning. I always thought it was the rear u-joint of the driveshaft.
    Aug 2010
    kent,il
    is this the noise i hear alll the time? a slight clunk or bang when i put it in gear or take off? sonds like it comes from the rear end....and it could be the nag i feel when it shifts..
    Registered User gungyspliff's Avatar
    SC
    I need to do this. Gettin tired of feeling like I have a bowling ball rolling around in the bed of the truck.
    Woodstock Ontario Canada
    Cool fix. Doesnt GM make a ncklle coated yoke where the nicle coating takes up some play to prevent the clunk?
    peace
    PAuly
    MI/AZ
    GM does have a nickle plated yoke and it can be covered under the bumper to bumper warranty.
    GM does not install the nickle plated yoke in production due to the vehicle being a high export vehicle and barred in many foreign countries.
