Thread: locker vs. posi
Results 1 to 20 of 28
    Sep 2010
    PA
    locker vs. posi
    i got a 93 c1500 nv3500 350. i drive on and offroad posi or a locker ????????
    Dec 2004
    Elkhart IN
    Re: locker vs. posi
    get something that replaces the entire carrier whatever you get. posi will be more street friendly, but the locker will be better off road. its a matter of give and take.
    Not Really Bob
    Newark, DE
    Re: locker vs. posi
    Eaton posi or Tru Trac. Detroit lockers are too expensive imo. Too expensive for a ten bolt. If you have a 14 FF the price is right, plus it's basically your only option for posi/locker.
    Registered User custm2500's Avatar
    Sep 2008
    Ohio
    Re: locker vs. posi
    If you are a weekend wheeler and don't beat it too hard then a posi is your best bet. Doesn't have teath to chew up on the street and the clutches will last half of forever.
    "01 GMC 2500 HD, Bagged, BB Tuned, Dumped exaust, and Race built trans with 2800 Stall
    Woodstock Ontario Canada
    Re: locker vs. posi
    Quote Originally Posted by custm2500 View Post
    I agree about the lockers, here is a link of the Eaton Detroit Locker and it has very similar "dog-teeth" that must ride on each other when the locker is "unlocked" like when turning coreners. These will eventually wear out, just liek the Lockrite from Powertrax.
    http://www.eaton.com/EatonCom/Produc...cker/index.htm
    Here is teh Eaton posi
    http://www.eaton.com/EatonCom/Produc...iLSD/index.htm
    I do hear of these wearing out, and IIRC, the carbon fiber clutches cant be used with the optional 800lb preload springs.
    and the True trac "torsen design"
    http://www.eaton.com/EatonCom/Produc...trac/index.htm
    peace
    Pauly
    Jan 2008
    Afton, WY
    Re: locker vs. posi
    Have you considered any of the lunchbox lockers? They act just like a Detroit. Never tried any myself, but from what i understand they are strong enough for 90% of people, cheaper, and easier to install.
    Registered User SierraDan's Avatar
    Feb 2008
    Olathe, KS
    Re: locker vs. posi
    Always heard good things about the True Trac torsion differential. Buy one of those, but weld the spider gears together on the stock open rear in the mean time and see how long it'll last
    95 Sierra C1500 SL (Sold to father-in-law)
    99 Suburban K1500 LT
    - Luke 1989K1500's Avatar
    Jan 2005
    Ravenna, Michigan
    Re: locker vs. posi
    I would get a posi, not a locker. But its up to you.
    Quote Originally Posted by bigbob6988 View Post
    Auburn and Detroit are the only options I know of for a 10.5. An Auburn is like 700 bucks though. But thats what Im going to end up with in mine, I dont want a full detroit with a loose converter, it'll be locked any time the truck is moving.
    Quote Originally Posted by wyo_driver4 View Post
    I wouldnt.
    WV Jeeper 94_c/1500's Avatar
    West Virginia
    Re: locker vs. posi
    The lunchbox lockers are really for someone on the cheap side without alot of power and not alot of use.
    When you say you drive on and offroad, how much do you do? Is it mostly street or mostly offroad? What is your idea of offroad?
    If you want all out offroad performance, then the locker would be better choice. The only real option for a locker is a Detroit Locker. I've never heard of anyone breaking one. But I have heard of people breaking a lunchbox locker or their factory carrier using a lunchbox locker.
    If the truck sees mostly the street and when you offroad its nothing extreme a limited slip would be fine.
    If you have enough money and still can't decide, then maybe a selectable locker is a good choice for you.
    Sep 2010
    PA
    Re: locker vs. posi
    i think im puting a 3/4 ton 14 bolt in the rear but that mite be alittle...... im thinking a limited slip.. i heard bad things bout lockers in the winter.
    West Virginia
    Re: locker vs. posi
    Lockers would help you out in deep snow, but on ice and packed snow they can be a bit tricky.
    There are 2 3/4 ton 14 bolts that came in these trucks. One is semifloating and one is full floating. Neither of them came in the 2wd 1/2 ton lug pattern.
    Sep 2010
    PA
    Re: locker vs. posi
    idk if its full or semi its coming out of an truck a gen before this truck to. im getting some noise out of the transmission to a very low deep grounding sound when letting off to go around a bend.
    Dec 2004
    Elkhart IN
    Re: locker vs. posi
    Quote Originally Posted by 94_c/1500 View Post
    wrong. 454 SS trucks came with a 14SF with a 5 on 5 lug pattern... aftermarket shafts are available, so its completely possible to build one using a 6 lug 3/4 ton 14SF.
    Registered User Stoked's Avatar
    Oct 2009
    Celina, Tx
    Re: locker vs. posi
    Personally, I would never run a lunchbox locker in any rear application.I just don't think they are strong enough, and by the time you've blown up the first one and replaced it, you could have had a full carrier replacement locker or limited slip.
    2005 Tahoe Z71
    2011 Jeep Wrangler Unlimited
    West Virginia
    Re: locker vs. posi
    I almost said something about the SS rearend, but he did say a 3/4 ton 14 bolt so I didn't bother saying anything about it.
    Sep 2010
    PA
    Re: locker vs. posi
    i have just alittle over 200000 miles on 1 trany, 1engine, i clutch.
    Sep 2010
    PA
    Re: locker vs. posi
    o and it had the **** beat OUT of it!!!!!!!!!!! over heated 3 times in 1 day and it still runs till this day!
    PA
    Re: locker vs. posi
    Where?
    14SF 5 on 5" shafts for the 454SS trucks have been discontinued for years , Dutchman was reportably making them but any phone call to them resulted in a "no we do not have an application for them". Moser will cut and respline original shafts as I have a set of those in my shop awating install into a 454SS rear that I narrowed.They will not custom make new ones.
    Anyway back on topic, Detroit locker hands down , especially if you plan on any power in the future.
    TOM
    1994 3500 Dually , 502HT ,264HR ,MPFI
    2006 Forest River 325RGT 5th Wheel
    2001 3500 8.1/Allison , HP tuners , Raylar, etc
    1993 K-3500 "Ex-diesel" , 454/4L80E
    1992 S-10 434 SBC/Tremec
    1984 S-10 Blazer BBC/700R4/205, SAS
    1980 Z-28 454 - 700R4
    1977 Olds 98 Regency 403/700R4
    1970, 71 and 72 GMC
    Registered User wpb0104's Avatar
    Sep 2010
    Cumming, Ga
    Re: locker vs. posi
    Posi is the way to go. i have a 90 silverado with 38s and 4.10 gears with a brute posi carrier in the rear and i love it. its so smooth and it works great. so much better than a stock locker or detroit locker. plus its cheaper. id say if you are gonna get a posi put it, go ahead and put new gears in too. you might as well since you are getting it setup. might save you time and money later
    Did someone say ponies? The Fiddle's Avatar
    Dec 2008
    Colorado
    Re: locker vs. posi
    Unless you are flexing your truck to the max, running in deep snow/mud/crud, then get a limited slip like the Detroit True Trac.
    Otherwise get a Detroit Locker.
    2015 Sierra 1500 Elevation Edition. "So impossibly black!"
    2005 Pontiac GTO LS2/A4. So fast it's gone now.
    1999 OBS K1500 Black Bear tuned 383 Z71. 2" rear blocks, Hankook MT's. Still around.
