Thread: transmission fuse keeps blowing out
Results 1 to 12 of 12
    Sep 2010
    montana
    first time on the board.
    I have a 1994 chevy silverado 4x4 350 c.i.d engine. my transmission fuse keeps breaking, and my transmission does not have too much take off power.
    Re: transmission fuse keeps blowing out
    your gonna have to check the wiring/connector going into the transmission.
    which gears is it missing? slipping?etc. ie starts in 4th might be a selenoid issue in the transmission. take it in or get a wire diagram.
    Matching Ninja 500r
    somewhere else
    So you're blowing the TRANS fuse, 10 amp at the bottom left of the panel?
    It's a single pink wire supplying power through the harness to the large round connector on the transmission.
    Could be damage in that wire somewhere along the line, or could be a problem internal to the transmission.
    Richard
    Last edited by someotherguy; 09-13-2010 at 09:29 PM. Reason: overlooked wiring diagram info
    Jul 2011
    IL
    Richard
    ****, whoever owned my truck before myself had a 30amp fuse in it. my trans was in limp mode, pulled the fuse and half of the plastic fuse case had started to melt.
    now i'm going to find that pink wire and see where it is melted at
    Registered User DylanC's Avatar
    Feb 2011
    Waxahachie, TX
    A 30AMP fuse in a 10AMP Slot :S its no wonder it may be melted
    System Administration Extraordinaire
    Proud member and contributor of FSC since 2011
    Servode.com | Dedicated Web Hosting and System Administration Solutions
    Registered User swanie2000's Avatar
    Jan 2009
    Las Vegas
    My 95 Tahoe just started this problem, blowing the 10am fuse #20(TRANSMISSION).
    I had just used my 4Hi lever in the truck, first time in months. It didn't blow right then, but a few miles down the road; I noticed that the speedometer, tach, and gear selector light were all out. I pulled over, and turned off the truck. After restarting, I went to put it in drive, and it would barely move.
    Found out later that the fuse was blown, and the transmission was starting out in 3rd, not 1st. Reverse still works, and I can manually shift to second gear, and 3rd gear. Of course this happened when I was 60 miles from home, so I limped the truck home, and have it in the garage now.
    So far, I have disconnected the two plugs on the side of the transmission, and the two plugs on the rear tail, and transfer case, and the number 20 fuse is still blowing instantly when you turn the car on?
    I was kinding hoping it was going to be the shift solenoid(s) but now that they are disconnected, and the fuse is still blowing, I don't know what else it could be?
    I looked it up on my "ALLDATAdiy.com" account, and found that the #20 fuse connects directly to the transmission shift solenoids, and that is all the schematic shows. However, the speedo, tach, gear selection indicator are also not working, so they are affected by the same fuse, but it is not listed on the schematic I have.
    Does anyone have the full schematic of the 1995 Tahoe? Or maybe can someone point me in the correct direction as to what would be the most likely place for this short?
    This is my daily driver, and it is not very drivable right now. All input would be greatly appreciated
    MI/AZ
    Might check on the 95 pickup diagram its the same.
    Jan 2009
    Las Vegas
    found some info on circuit 1020, fuse# 20 on google.
    it is saying ignition switch, i am tearing into that at the moment.
    will post back with info....
    Jan 2009
    Las Vegas
    Well it's not the ignition switch.
    Found the wire at the ignition switch and cut it. Fuse #20 holds good, with truck running, and the wire cut.
    Applied power to the harness side of the wire through an external 10 amp fuse(by passing the ignition switch) and the fuse blows.
    So it is something down line of the ignition switch.
    Still open to ideas.....Please!
    Jan 2009
    Las Vegas
    OK, I found a 5th plug on the transmission, it was round, and on the passenger side. My short is coming from in there.
    Not fixed yet, but at least it is narrowed down to one area.
    Mar 2015
    522 Wildwood St. Mary Esther, Fl 32569
    Quote Originally Posted by swanie2000 View Post
    I have the same problem, if you fix it let me know please.
    Big D Runner
    Jan 2009
    Las Vegas
    Quote Originally Posted by Big D Runner View Post
    Big D Runner
    Wow, that was a long time ago.
    IIRC, the problem was inside the transmission. It was the 3-2 down shift solenoid.
    The transmission shop replaced that solenoid, and also the internal wire harness which was old and brittle.
    Hope this helps!
    Swanie
