Thread: replace pick up coil
Results 1 to 4 of 4
    Sep 2010
    illinois
    I need to replace the pick up coil in my distributor. 1993 K1500 w/ 5.7
    How do you get it off?
    Sep 2006
    SAN ANTONIO
    Re: replace pick up coil
    Just unscrew the cap under cap is coil. Unscrew the coil and replace theres no wrong way to put on.
    MI/AZ
    The pickup coil requires you to remove the distributer, drive roll pin out of the gear and pull the shaft out, then change the coil and reverse the job.
    Turbo & sealants GURU
    Middletown Ohio
    Yup just did mine...Check it with a ohm meter first...Save you the trouble if it aint bad. Several people here know the reading you should see. Mine was good and I did it for nothing....Oh well live and learn.
