Thread: 1998 5.7l chevy tahoe died while driving?
Results 1 to 20 of 20
    Apr 2010
    NE
    need help in fixing 1998 chevy tahoe with a 5.7 I tuned it up with new plugs and air filter 3 weeks ago and it was running great and while driving today it died while driving 45mph and won't start it turns over good but won't start....I poured gas in the throttle body and it isn;t getting spark. I replaced the cam sensor and crank sensor and ignition control module but still no spark......any ideas?......thanks...Tom
    I am sinner JWolfe75's Avatar
    Nov 2004
    NJ
    Re: 1998 5.7l chevy tahoe died while driving?
    have you checked the cap and rotor?
    '05 GMC 2500 HD LLY
    '07 TBSS AWD 3SS
    Apr 2010
    NE
    yes pulled the cap and rotor and checked they were good also pulled and checked the coil wire it was good was going to pull the coil and have it checked but I can't get it off not sure how it's bolted on?
    I am sofa king we tod did LikeARock47's Avatar
    May 2010
    Philadelphia area, PA
    Could be the distributor pickup coil, if so it will have no spark and the fuel injectors will not fire.
    Apr 2010
    NE
    is it the coil that has the ignition control module mounted on it?
    Apr 2010
    NE
    sorry I know what your talking about now....yes that was the first thing i replaced under the distributor cap....
    May 2010
    Check the easy stuff like fuses?
    Apr 2010
    NE
    yep pulled them all checked in the bright sunlight....strange thing is that when it died it had a 1/4 tank of gas and when I tried to restart it everything was normal on the gauges but the fuel gauge was pegged past full...
    King Butcher IH8FORD's Avatar
    Jan 2004
    buffalo ny
    your ecm1 fuse in the under hood fuse block is good?
    1999 tahoe limited. DD (sold) replaced with 09 crew cab.
    1988 gmc rcsb winter/plow truck
    1995 gmc ecsb project truck
    Apr 2010
    NE
    if your talking about the 50 amp fuses then yes they were all good I puled and checked all the fuses under the hood and all were good....
    Dec 2009
    Coastal Carolina
    Did you measure the voltage at the distro and coil ?
    My redneck is coming out here, pull a plug cap and listen for spark ?
    Do the 1-2-3 thing. Follow the electricity from the source to the plug.
    Apr 2010
    NE
    will try it the morning......i'll post what I find...
    Sep 2010
    southern ohio
    i had the same thing happen on a 98 ecsb with 305 pulled out on highway and it just died with no spark replaced coil and module first still nothing then pulled the cap and one of the screws backed out of rotor and destroyed everything under the cap put new rotor button in still nothing well come to find out after tearing the front of the motor down just to find a in time timing chain that when the rotor button came lose it actually spun on the shaft so i had to get a new distributor and re time it that rotor button sets on a plate that is just a press fit nothing else hope this helps
    Apr 2010
    NE
    update....pulled a plug and cranked and no spark so replaced rotor and cap still no spark so with ignition on checked voltage at icm read .25 volts checked voltage at coil .10 volts so no what should I check? not sure what comes before ignition control module?....
    Apr 2010
    NE
    update...after 15 hours of trying fix it I took it to the dealer and dropped it off now I just have to put with the wife telling I told you to take it to the dealer yesterday!
    Jan 2004
    buffalo ny
    that sucks hopefully its a cheap fix.
    Sep 2010
    southern ohio
    sorry i wasnt more help i worked on mine for two days replaced everything ignition wise and it would just backfire thru throttlebody found out that when i put the new disributer in i just put in in the same way the old one came out wel it was 180 degrees out where it had spun on the shaft pulled it back out turned it around fired as soon as i turned the key i spent alot of unnesasery money but thats how it goes when u work on something it seems like
    Apr 2010
    NE
    Well I look at it this way the stuff I replaced should have been done on a full tuneup fro the dealer....
    Apr 2010
    NE
    update.....117.00 dollars later and the dealers said it was a blown ECM relay so it was a cheap compared to ignition fuel pump replacement....Thanks for all the it was a learning experience now I need to know how to quiet the wife who keeps saying you should have taken it to the dealer in the first place.......
    Nov 2004
    NJ
    Quote Originally Posted by tomatgladstone View Post
    Good luck with that, post up if you find a solution :aniteef:
    '05 GMC 2500 HD LLY
    '07 TBSS AWD 3SS
