Thread: i3owdown's 2DR Tahoe Build (slammed on 22s)
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 120
    Registered User i3owdown's Avatar
    Aug 2008
    orlando
    it feels like i have been working on the tahoe forever but and finally starting to see light at the end of the tunnel. truck began as a stock 99 2 door tahoe with 76,000 miles on the clock.
    Summary of mods to date include:
    escalade front grille, fenders, hood, lights
    gmc sierra chrome front bumper
    shaved roof rack
    steel rollpan
    full paint job
    air ride tubular upper and lower control arms with djm 2" drop spindles
    kp components parallel 4 link with panhard bar and cantiliver kit modified to fit
    2 dr blazer gas tank
    22" intro wheels
    i will be posting a bunch of pics in order by date. enjoy
    Aug 2008
    orlando
    Re: i3owdown's 2DR Tahoe Build (slammed on 22s)
    here it is stock
    Aug 2008
    orlando
    Aug 2008
    orlando
    used aftermarket fenders without holes. they were a waste of money, they were very light gauge material with sharp edges and fit terrible. they were pulled off and replaced with factory fenders found at a salvage yard. cheaper and fitment wasperfect and easy to install. i then had to remove the cladding and shave the holes
    Aug 2008
    orlando
    paint time
    i love these next two pictures. looks like black and white
    Aug 2008
    orlando
    colors used are: chevy strom grey metallic and honda beliz blue metallic pearl
    Aug 2008
    orlando
    Aug 2008
    orlando
    purchased djm drop spindles from stylin concepts that came in damaged without me noticing until 6 months later when its time to install. stylin did not want to help in any way. instead they offered to sell me a new set of spindles at 40% off, which ends of posting more than what i payed for them originally. thanks alot stylin.
    djm agreed to replace them however, shipping costs were $50+ to california from florida. they soon changed their minds with helping and i ended up having to repair. they didnt even want to help me with a rethread die. anyway, they were repaired and i swapped them with the belltech spindles that were already installed to pull the wheel in a little more. the djms pulled the wheel in about .25" from the belltech spindles. i took pictures of the difference but i cant find them right now. i will post later if anyone cares to see.
    used air ride tubular upper and lower control arms with firestone 2700 airbags
    Aug 2008
    orlando
    i have to give credit and thanks to fullsizechevy and Nickleahy23 for his "Dont know if we have this but.. All the info to lay fram on 22's..OBS" thread
    http://www.fullsizechevy.com/showthr...e-on-22-s..OBS
    Built, not bought. Bad Bowtie 91's Avatar
    Augusta Ga.
    Looking good man!
    You don't see many 2dr hoe's like that.
    91 ECSB, 305 bored .30 over, Flat top pistons, Summit Racing 272/282 cam, Holley carb, Edelbrock intake, Accel HEI dizzy, 801 heads, 700R4, 3.42's open.
    Chevys for life 73impala's Avatar
    Margate, Florida
    great looking tahoe man!
    2003 Chevrolet Silverado - 2500hd duramax 6.6l lb7 allison transmission 3 inch body lift muffler delete
    Aug 2008
    orlando
    now to the back suspension. the main goal is to lay frame out back but most importantly, keep my rear seat. i have seen too many 2 door builds without the rear seat. in fact, i have yet to see one keep the factory rear seat. i did some math and i should also be able to keep the rear plastic panels without cutting for wheel tubs. this is where i am currently at in the build.
    a 1988-1998 gm 1500 series bolt on parallel 4 link and cantilever package was used. the forward bars where cut back and re-threaded. the cantilever bracket was cut down and shortened. the bag bracket needed to be moved towards the back 5" and new holes where drilled to mount the lower cantilever bar 1.75" farther back. the lower cantilever bars were also shortened.
    the factory gas tank was too wide to fit the panhard bar so i purchased a tank from a 2000 2 door blazer. it is less deep and should provide enough space for the panhard bar. it also doesnt hang as low below the rollpan as factory tank.
    Aug 2008
    orlando
    Aug 2008
    orlando
    Aug 2008
    orlando
    Aug 2008
    orlando
    that is it for now. thats 1.5 years in the making. should be complete to debut at unite 2011.
    things to do: finish modifying and installing 4-link, weld in cross members on c-notch, mount new gas tank and figure out hook up. fabricate and weld in new sheet metal tubs, notch cover, and driveshaft cover.
    i am using a 00 2 door blazer tank for my 99 2 door tahoe. should be pretty straight forward to mount. using stock crossmember in the rear and welding in a new one up front. one pigtail on the sending unit is the same (assuming its the electrical for fuel pump) the other is different but have pigtail to match, no big deal. two of the nipples for fuel connections are the same but the one in the middle is different. my tahoe nipple has a flange on the end of it, the blazer doesnt. what can i do to retrofit fuel line to new sending unit. they are both plastic so i dont trust clamping down hose to nipple. any ideas?
    Car Audio GURU 12VoLt ShOcKeR's Avatar
    Oct 2008
    Oklahoma
    That is a clean hoe and props on all the work you have done!
    As far as the fuel line there might be a connection point between the tank and the front of the truck before it gets to the motor...Trace it out, and you probably can pull the whole line and swap it for you style... Or I would look at swapping the Pump over to the new tank... that would solve allot of issues... Dunno if it helps I have never worked on a 2door hoe but that is just a thought...
    Registered User Tigwldr's Avatar
    Jul 2008
    NC
    Awesome job i3 , it looks amazing.
    I have been wanting a 4-link for my 2dr for years with the same ideas to keep my seat and not have to modify the rear section much if at all.
    Quick question, just looking for others opinions especially ones who have experience in this department.
    From a performance/DD point of veiw. What do you think of a tri-4-link something like thiese for our trucks? Otherwise I'll more than likely be using SDs parallel 4-link http://www.suicidedoors.com/4-link-k...lel-4-link-kit
    This is a 67 C10
    This is a 69 Chevelle
    Thanks man
    Great work.
    Registered User minorobsession's Avatar
    Oct 2005
    Michigan
    Did you forget to paint the hood? LOL, looking great man, love the color combo.
    Jersey
    wow awesome work.
    2001 Tahoe LT 5.3 4x4
