Thread: Hesitation/Runs Rough when warm and only a cruise speed
Results 1 to 10 of 10
    Jul 2010
    Fort Wayne
    1990 K2500 5.7L TBI
    I appreciate any advice. My truck runs really rough and hesitates only after the engine has warmed up and only when I have slight pressure on the gas pedal. I don't notice any hesitation when accelerating. I don't really notice it at slower speeds either (but I'm not 100% sure if it isn't happening). But if I try and hold the speed at 55 mph, it hesitates and jerks, etc.
    Thanks!
    Workin on a loapy 383 Hicks-MofG's Avatar
    Kentucky
    Re: Hesitation/Runs Rough when warm and only a cruise speed
    Check the EGR system.... make sure its not drawing air. that could lean it out.
    WIP-1997 K2500 Ext Cab
    Volant CAI-BBK 85mm TB-Marine intake-32Lbs Injectors
    Patriot Vortec 185cc, Comp 1.6RR, 224/230-573/568 LSA113
    KB Pistons Thermal/Friction Coated, SCAT 383 Rotating, 6" Rods
    MSD Digital 6, HVCII Coil, 2200-2600 Stall, E-Fan, UD pulleys....
    http://prosilversystems.com
    Jul 2010
    Fort Wayne
    Quote Originally Posted by Hicks-MofG View Post
    Thanks. I did check the egr valve. It seems to be working fine. I did unplug the vacuum line from the egr valve and it still has the hesitation problem. Any other thoughts on how to check out the egr system?
    does the check engine light come on and then goes off during the hesitation?
    Matching Ninja 500r
    Full time lurker jerome99's Avatar
    May 2005
    Little Rock
    Thats the same thing mine is doing. NEUMANNZZ is a good resource, smart guy.
    My truck is a money pit with no bottom.
    1996 K1500 5.7 Vortec
    Jul 2010
    Fort Wayne
    The check engine light does come on sometimes, but not right when the hesitations start. If I drive it for a long time, the check engine light comes on, but when I start it up again after shutting it off, it is gone.
    I don't know if it is related, but this truck idles extremely high when in park...
    Jul 2010
    Fort Wayne
    I do think it is EGR related now. I pulled the vacuum hose from the egr valve and plugged it up. I'm not getting any of the hesitations now...
    replace the egr valve with an oem. not autozone crap.
    Matching Ninja 500r
    Jul 2010
    Fort Wayne
    Thanks. Do you think this is at all related to why it is idling so high? Or would you suspect another issue?
    yes it could be related to high idle vacuum leak.
    Matching Ninja 500r
