Thread: 99 Suburban K1500 brake lights and blinkers don't work
Results 1 to 11 of 11
    Registered User Swearingsailor6's Avatar
    South Dakota
    The brake lights and blinkers are not working on my 99 Suburban. I checked the fuses (by the dash) and they are all good there, and checked the relays under the hood, and where, according to the cover, the brake light and blinker relays are supposed to be, there aren't any relays or even contacts for relays. the cutouts are there, but there aren't any contacts there for the relays to plug into.
    Everything else under there seems to be fine. Where or what else can I check??
    2000 Chevy Silverado K2500 6.0
    1999 Chevy Suburban K1500
    1979 Chevy Silverado K10 454 4x4
    Maine
    Re: 99 Suburban K1500 brake lights and blinkers don't work
    Sounds like a multi function switch to me.
    South Dakota
    where would that be located??
    Maine
    Steering column. Operates blinkers, hi/lo beam, cruise, wipers, 4ways......
    Dec 2007
    Dillon, MT
    KISS principle: you did verify that bulbs aren't blown, right?
    Next, check if the front turn signals work at all. If not, THEN start tearing into the multi-function switch.
    '98 K3500 7.4Vortec/4L80E, airbags, Bosch injector upgrade, Magnaflow exhaust, custom tuned by me!
    Click here for Vortec distributor cap info
    Oct 2010
    irvine,ky
    all i can say is have fun my 98 burban did this and it was the multi function switch the little red button on the top of colum was broke on mine ( here is what i did ) i bought a whole colum for mine (70 dollars ) and is easy to swich out ! lot easier than doing the switch to me ( i did not want to play around air bag and all that ) dont worrie its easy to reprogram the computer when you get new colum in there it only talkes about 40 to 45 min to switch out colum and reprogam it and then you back on the road again !
    Maine
    You don't have to touch the airbags to change the switch.
    Jan 2010
    NC
    Quote Originally Posted by 2COR517 View Post
    On my '99 k1500 OBS you do have to remove horn/airbag cover. Manual says you have to remove steering wheel but you dont. You can get to the two screws without removing wheel.
    Oct 2010
    irvine,ky
    can you give me something to let me know how to do it with out touching the airbag or steering wheel cause i have two more sitting here one is good and one is bad and i could put them together and have one more good one for my truck ( 98 burban suck cause only 98 will fit and most of them are broke ) thank guys for the help
    Oct 2010
    irvine,ky
    all i need to know is where do the wires come from that plug in to the passangerside of the tranny ? i have got all the other one where they go too now i just have blue/white stripe , black/white stripe , red/ white stripe , yellow/whitestripe , brown ,green . any help on these wires i know they plug in to the passanger side of tranny but where does the other ends of the wires go
    South Dakota
    It was that switch...I took it back to the dealer i bought it from and they fixed it for free! I have bought numerous cars from them and I guess it was time for them to pay me back. Thanks for the help guys.
    Ryan
