Thread: how to remove quick connects
Results 1 to 13 of 13
    Keepin it Reeeeeeel $gmoney$'s Avatar
    CALIFORNIA
    I have a 2001 Silverado and my heater isn't blowing warm air anymore. I'm trying to flush the heater core but am stuck on howto remove those stupid quick connects. what's the easiest way to take them off?
    2001 Chevy Silverado 1500, Fabtech 4" spindles on Eagle alloy 063s on 33" bfg all terrains, Limo Tint
    http://www.cardomain.com/ride/3067770
    Registered User Rough's Avatar
    Feb 2007
    PA
    Re: how to remove quick connects
    There's a special tool, looks like the tool used to separate fuel and air conditioning lines except it's a little longer.
    CALIFORNIA
    Happen to know the name of the tool?
    May 2009
    haverhill ma
    I believe you can get it at any parts store im not sure the name of it. I had the same issue on my 97 and it turned out to be the fitting that's in the intake it was all junked up I replaced it and was good after that
    Old Man Mountain Swaggerwagon's Avatar
    Tennessee
    Registered User woody2dtahoe's Avatar
    Nov 2006
    Orange, Connecticut ......
    Hey , just my input here ... but a buddy of mine has an NBS and lost his heat as well. We changed the cold air door motor and he got banging heat back in his truck.
    Step 1: remove the cover that covers the heater box and pass side floor area below the glove box. (3 10mm bolts)
    Test 2: locate the small motor directly under the heater box (very accessible) move heater control from cold to warm and place ur finger under the motor, half the shaft that controls the door sticks out far enuff under the motor to feel it move.
    Step3: replace it if it doesnt make a full 90 degree turn.
    I have all OBS or I would provide pictures .... We flushed his heater core too and still nothing ... replaced the motor and it worked. The door controls fresh/cold air comming into the heater vents.
    97 Chevy Tahoe SAS project 14" lift 79 D60 kingpin AAM SF10.5
    96 Tahoe 6" superlift 3" BL
    99 Tahoe 4 door
    01 Honda RC51 ... too many mods!
    Aug 2002
    SYRACUSE NY & ALEXANDRIA BAY NY
    Try the "blend door" reset procedure !
    As easy as pulling the fuses..............
    The correct procedure is posted around here somewhere!
    CALIFORNIA
    For someone in the future trying to fix their heater also, I just back flushed the heater core and my heater seems to work great right now
    this tool: http://www.sears.com/shc/s/p_10153_1...&blockType=G24
    will work to remove the quick connect at the heater core hose at the firewall, they carry the tool at kragen/orieleys, sears happened to have a nice pic tho
    somewhere else
    Sears has these too:
    Hope GM started making the quick connect heater fitting out of something better than that cast junk they cursed us with on the GMT400's.
    Richard
    SE Michigan
    Richard
    GMT800's have PLASTIC quick connects on the hoses to connect to the heater core, they break all the time
    2000 Silverado 6.0 4L80E 2wd
    Registered User OneBaddAssZ71's Avatar
    Jun 2007
    Lynchburg, Va
    you dont need to remove the quick connects just get yourself a pair of pliers and open the clamp and pull the hoses off.
    here is a pic of the clamps just squeeze them and the hose will come off. this is how i took my hoses off my 2000nbs to flush my core or your you could also take the hoses loose down at the pump and flush it that way with a water hose
    Feb 2007
    PA
    Quote Originally Posted by $gmoney$ View Post
    Quick Connect Connector Removal Tool, PN J43181, OTC makes it.
    somewhere else
    Quote Originally Posted by dave89iroc View Post
    Jeezus, just when I thought they couldn't make them worse.
    Richard
