Thread: no power to fuel pump. good fuel pump, relay and fuse. any ideas?
Results 1 to 9 of 9
    Arkansas
    hey i have a '90 with a tbi 350. I have no power to my fuel pump. i tested my pump, its good. fuse is good and i replaced the relay. Is the only thing left to check the wiring? If so there are five wires going to the relay. what should i look for when i use my test light?
    Thanks,
    Nov 2008
    Canada
    Re: no power to fuel pump. good fuel pump, relay and fuse. any ideas?
    Power goes from the oil pressure sending unit behind the distributor to the fuel pump If I recall.
    I am sofa king we tod did LikeARock47's Avatar
    May 2010
    Philadelphia area, PA
    Does it never have power to the fuel pump, or will it prime when you turn the key on? If it primes, that means the pcm is not turning the pump on. Which usually means it is not getting the reference signal from the ignition module.
    94 Chevy K1500, 350 V8 extended cab stepside 4x4
    Nov 2008
    Canada
    Yes my ignition module failed before and I nearly dropped the gas tank :). Found out it was that causing no power to my fuel pump.
    Registered User Silent_Monster's Avatar
    Dec 2010
    Alice
    i just had similiar problems. replaced fuel pump and still no response. all lines had juice going through them and relays were good. but the fuel pump itself was not getting any juice. there is a wire that goes directly to the fuel pump. you have to take out the fuel pump from the tank to get to it. the connector to the fuel pump was melted. the previous fuel pump had shorted the wire out and melted the plastic casing. i used a knife to cut off the extra plastic. plugged the connector back into the pump itself and problem solved. make sure none of your wires are shorted out.
    Arkansas
    the fuel pump never comes on. I have the bed off. the wire going to the pump never has power. where is the ignition module located?
    Nov 2008
    Canada
    Under the cap of the distributor, it is the electronic part that has the harness connect to it.
    Jul 2006
    whoknows
    make sure the ground connection for pump is perfectly clean and clear. corrosion is a mothertrucker.
    Matching Ninja 500r
