Thread: 2007 silverado classic OBD2 Code reader not reading ?
Results 1 to 7 of 7
    San Jose, CA
    So my sisters 2007 silverado classic check v6 check engine light came on.
    I plugged in my OBD2 Code reader and It would not read or be powered by the plug as it normally does.
    I searched and found others say I would either need a (can reader ?) or there is a fuse that is out.
    I searched all the fuses and did not find anything that was out. Also the cig lighter and every other feature works on the car.
    Anybody else experience this?
    Thanks
    Lanark, Ontario
    Re: 2007 silverado classic OBD2 Code reader not reading ?
    I had trouble getting my 07 classic to read the other day. It was -10'F outside, and the code reader in my buddy's truck.
    After a little time and a few power cycles, it read fine. Took about 2 min to actually connect when it finally did though.
    San Jose, CA
    damnn, that is frigid. Yeah I plugged it into my 01 tahoe and worked fine. then go over to the 07 and nothing, 1st it powered it on,
    but didnt show the ( vehicle Link) icon, then it wouldnt even power it on.
    Damn thing
    Lanark, Ontario
    Quote Originally Posted by D1BADZ View Post
    Damn thing
    Yeah, was doing the same thing to me. Would read my buddy's 02 Sonoma right away, but took some time to connect to my Sierra.
    Midwest FSC Chapter!!
    Illinois
    if it doesnt work after a few tries, check the fuse, most of the time the data link and the cig plug in are on the same fuse and they like to blow alot
    97 z71,3" body lift, tow mirrors, cranked and AAL, 35" KM2's, 4.56 gears w/lockright, 6k HID's, strobes/lightbar/leds
    06 2500hd 6.0 gasser, 4" lift, 37" Toyos on 20" rockstars, 20" lightbar behind grill, colormatching in progress
    Registered User Bowtie00's Avatar
    Oct 2008
    Dallas, TX
    it needs to be can obd2
    2000 Chevy Silverado 1500 4.3L 5 Speed
    Jun 2010
    Alberta, Canada
    You likely have no power at the data link connector because the 15 amp cig lighter fuse in the underhood fuse box is blown.
    Gov't/ASE Certified Master Automotive Technician w/ Red Seal
    2000 Chevrolet K2500 CCSB 454
    10:1 compression, ZZ502 cam and timing set, adjustable valvetrain, roller tip rockers, custom heads, Bosch 30lb injectors, custom programming, custom exhaust, high volume oil pump w/ steel shaft guide.
