Thread: Time to change coil packs on a 5.3 ls engine?
Results 1 to 16 of 16
    seminole,florida
    I have a 2001 Chevy Z71 with the 5.3 ls engine with the coils mounted on the valve cover i got the truck used with 63,xxx miles on it it now has 126,xxx miles on it and was thinking if it was time to change the coils and if i should go with the facotry replacment ones since i work at a dealer ship group and can get them at a discount or go with like MSD or another brand what do you guys think thanx...
    Re: Time to change coil packs on a 5.3 ls engine?
    whats wrong with them?
    Dec 2010
    Oak Park Ca.
    Is there some reason you are considering changing coils, driveability or ?, or are you just looking for a reason to spend money?
    MI/AZ
    If its not broke leave it alone. I have a 2000 5.3l with 270000 mi and still has the same coils, injectors and engine has never been opened up.
    S.E. Wi.
    Spark plugs are items needing replacement, coils should be good till they die and are not a item that requires replacement on a time or mileage schedule.
    Registered User FountainGuy214's Avatar
    Oct 2010
    Louisiana
    Speaking of changing spark plugs on a 5.3, how the hell do you take the boots/wires off the plugs??? No matter how hard i pull or twist on the stupid a$$ things, i cant get them off.
    F-body whore LS1Mike's Avatar
    Jul 2006
    Bremerton
    Quote Originally Posted by FountainGuy214 View Post
    Are you putting new wires on? On my Trans Am I sprayed a little WD-40, let it soak a little and it came right off.
    Mike
    2002 Silverado 2500 HD 6.0
    1989 Sierra 3500 BBC
    2007 Chevrolet Equinox LT
    2000 Trans Am WS6
    1998 Buick Regal GS
    1995 Fleetwood Prowler 25 Foot 5th wheel
    Oct 2010
    Louisiana
    Quote Originally Posted by LS1Mike View Post
    nah im not changing the wires, just trying to change the plugs
    Jul 2006
    Bremerton
    My WS6s were stuck on there. I did the WD-40, but put new wires on. Not sure if the WD-40 will hurt them or not.
    Lot more room to get them off in the truck. Good luck!
    Mike
    2000 Trans Am WS6
    1998 Buick Regal GS
    Aug 2009
    C.A. High Desert
    when replacing the plug boots, put a lite coating of dielectric grease inside the plug and coil boots and they will go on and off a hole lot easer next time they need to be pulled off..
    Feb 2007
    Ithaca, New york
    they make boot pullers, go to a auto store and buy one, work great IMO
    2003 Chevy silverado ecsb, 285/75/16 tires, not cranked.
    1987 Monte carlo, 2/4 drop, 383 stroker, 16" M/T street/strip tires
    Cape Cod, MA
    Not to thread jack, but what about plug wires? If they are in good working order but have some miles on them, is it worth it to replace them for maintenance sake?
    Back to the subject of the thread, I agree that if the stock coils are still getting the job done, leave them be. There has been no evidence to support that spending more money on MSD's or other ignition manufacturer's aftermarket coils will do a better job than the stock coils.
    S.E. Wi.
    Plugs should be good for a 100k miles so I'd replace the plugs and wires at the same time. JMO
    SE Michigan
    Quote Originally Posted by mudbuddy View Post
    thats what i recommend
    2000 Silverado 6.0 4L80E 2wd
    seminole,florida
    i have been having isues with the truck the last 2 years with the gas use going way up not getting the mpg like it used to get and was just wondering if the coils were wore out or needed replacement no one at the chevy dealership can give ema stright answer and every shop i ask says of corse change them its should be done so was asking you guys if u had any ideas on if i should or not
    MI/AZ
    If you had coil issues the PCM would set a code for mis fires. If you do not have any thats not the problem.
