Thread: bad fuel pump? Pressure regulator? 2001 5.3L
Results 1 to 3 of 3
    Jun 2010
    South Dakota
    Fuel pressure test results, 2001 suburban 5.3L:
    key on (cycled 3 times or so) 45 psi
    engine on and running (idle) 50 psi
    idling, with Vac. line on Fuel Pressure Regulator pulled : 58 psi
    engine shut down: 45 psi
    after ten minutes: 38-39 psi
    This morning, at about -5 degrees F, I needed to cycle the key about 7 times before it would start.
    I replaced the fuel pump with an "Airtex" about 1.5 months ago. I did not check the pressures at that time.
    There was no fuel dripping from the vac line on the FPR.
    I did replace the fuel filter at the time of the pump replacement, FWIW.
    Bad FPR? I guess the way to check is to somehow block off the return hose and watch the fuel pressure, correct?
    Bad Fuel Pump? I hate to consider this, but it is possible. Last time, it was about 10 hrs of my time. This time, maybe 4-6 hrs, but I hate to do that again.
    Thanks in advance,
    Cape Cod, MA
    Re: bad fuel pump? Pressure regulator? 2001 5.3L
    Hate to say it, but I'd suspect the fuel pump.
    A bad FPR typically causes a prolonged start, but it does eventually start. Once it does start, it sputters for a few seconds while the signature cloud of rich mixture smoke exits the tailpipe. This doesn't sound like what you have going on.
    Nov 2010
    Calgary
    Right before my fuel pump went, for about a month before when it got really cold, it would start fine, then chug out. I would have to stay outside until it warmed up a bit with my foot on the accelerator. The check engine light that came on for me was P0172,and P0174 (engine to lean bank 1 and 2) Also it kept saying random multiple misfire. Then it just started chugging out while driving and the fuel pump was shot. Try some fuel line anti-freeze maybe. I didn't have the idea to check the fuel line pressure. If you just replaced the pump you should be able to get warranty on it?
