Thread: Vortec CSFI to MPFI conversion
Results 1 to 8 of 8
    Feb 2011
    phila pa
    Has anyone done this swap? I have only found one company that does this conversion? theautoshop.net/VortecMPFI.htm .
    Are there any other companies that have a similar kit? I am building a 383 stroker for my 96 Chevy Express conversion van 1500. I know the spider injectors are a problem area and I want to upgrade it while everything is out!!! Any info is greatly appreciated!!!
    Chuck
    Maine
    Re: Vortec CSFI to MPFI conversion
    All you need is a replacement spider. You can get them from AutoZone, Carquest, dealer, etc. Bought mine from AZ. GP Sorenson with Delphi injectors. Works great.
    Feb 2011
    phila pa
    I have read that the factory spider is prone to failure? The MPFI conversion will give you better performance and economy and is more reliable. This is for a 383 stroker also. I just don't want to have to replace something down the road that I can do now.
    Woodstock Ontario Canada
    This PDF file shows how to unstick stock poppets and how to install the MPFI conversion.
    http://members.shaw.ca/betterthanyou...g%20Poppet.htm
    The MPFI and CSFI spiders flow teh same amount of fuel 23.1 lb/hr at 62psi of fuel pressure, though they may be more reliable.
    peace
    PAuly
    Nov 2009
    Minnesota
    I did it on my 97 I got the injector assembly from orielly auto parts. Cost close to $300 but I feel it was worth it.
    FullSized Mini VortecBlazer's Avatar
    Jul 2006
    North Florida
    i checked ebay from time to time and found a damn good deal on a new set.....also found a good deal on a used set for the wife's xtreme
    Don't Bitch About Mistakes, Learn From Them!
    Transmission built by Transbuilderguy
    0411 PCM SWAP!
    Registered User thej0ker's Avatar
    Gulfport, MS
    I thought I was going to be needing one and found where some one suggested this injector kit at rockauto part# FJ10566. I don't have to get it now but plan to do it in the future as an upgrade. Good price too $289 and it's manufactured by Delphi.
    Big Truck Driver Tony 2-Tone's Avatar
    Jul 2006
    D/FW
    Sub'd.
    -Brandon
    2006 Super Black Nissan Altima SE-R
    1996 Chevrolet Suburban LT (work in progess)
    1981 Chevrolet Silverado RCLB (heh, try me)
    team driven!
