Thread: LED bulbs to replace the soldered instrument cluster bulbs- How to...
Results 1 to 20 of 20
    Dec 2008
    Carthage, NC
    I don't post here, like, ever really, but have used the site as a resource for my wife's 2005 Silverado Z-71. I recently went through replacing all the servo motors in the instrument cluster when the tach and oil pressure gauges went whacky, and in the process, learned about how the back lighting bulbs are soldered on to the circuit board instead of being replacable from the back like they use to be. What kind of crap was GM thinking with this design anyway?
    I wanted to replace the bulbs, but I wanted to do it with LED bulbs for longevity. Unfortunately, I could not seem to find a source, so this is what I DID find, and ended up using.....
    From www.superbrightleds.com, I found the NeoWedge series bulbs that are designed to replace the twist lock bulbs that are replaceable. They make these in three different sizes, and when I measured, the 3mm bulbs came really close, so I ordered 10 of the high output 3mm LED bulbs, found here:
    http://www.superbrightleds.com/cgi-b...nstrument.html
    These are the NEO3 series bulbs, and I thought might fit the bill for this project, and they did....
    Step one.... Remove the instrument cluster and separate the sections. I use Scotch tape and rotate the needles all the way counterclockwise, and mark where the needles stop so I can put them back to the same spot later.... Just twist the needles to break them loose and pull off.
    The instrument cluster circuit board. I have all the bulb areas circled, though it might be hard to see. My cluster had 11 bulbs, with a solder point for a 12th bulb to the lower left. I don't know what gauge goes there, but mine does not have one.
    Here is how the stock bulb looks. You can see the solder points. To remove, use a solder iron and put pressure on the opposite side when the solder melts to break it loose, then do the other side to finish removing...
    Installing the LED bulbs is simple, but you MUST orient them for proper polarity. Standard bulbs will work when mounted with the contacts on either solder pad, but LED are polarity sensitive. What I did was hook the circuit board up to the truck and turn the lights, including the flashers, on, then touch the bulbs to the solder pads and mark which way was the correct orientation. You can see some of the Sharpie marker on the board. Then I soldered the bulbs in place. The wires wrap around under the mount, just like the stock bulbs, so tin them a little with solder, and then solder in place keeping the polarity correct.
    This is how the new LED bulbs look when they are in place...
    How it looks at night.....
    Hope this helps some of you.....
    Ron
    MSgt, USMC (Retired)
    Lost before Dawn CustomChevyGuy's Avatar
    Aug 2004
    305, South Fla
    Re: LED bulbs to replace the soldered instrument cluster bulbs- How to...
    those are great photos! have any of the finished product? how is the light output, and do you have any hot spots?
    Quote Originally Posted by bhookxen
    sometimes bad-assery takes time
    71 Chevelle 454
    03 rcsb, 06 clip/tails, HD hood, Esky handles, Alpine head unit, 5% tint, clear corners, 8K HID's, FM50, 2" rear drop, debadged, BlackBear Tuned!
    Houston, Texas
    That a nice design very clean. But I do wonder on your hotspots. I did see you used smd leds. Which are brighter than regular leds.I like your concept a lot makes me want to redo mine and put some 360 leds
    Registered User Stoked's Avatar
    Oct 2009
    Celina, Tx
    Nice work!! I may have to give this a shot!
    Quote Originally Posted by meanstrk View Post
    The instrument cluster circuit board. I have all the bulb areas circled, though it might be hard to see. My cluster had 11 bulbs, with a solder point for a 12th bulb to the lower left. I do know what gauge goes there, but mine does not have one.
    That's where the trans temp gauge goes on trucks that have it.
    2005 Tahoe Z71
    2011 Jeep Wrangler Unlimited
    Dec 2008
    Carthage, NC
    Sorry about the belated reply. Been travelling for work....
    If I were to do this again, I would use the regular output LED's. They are about half the cost and the light output with these is almost TOO bright! It looks great though. My wife really likes how well she can see the guages now. No real hot spots at all.
    I'll have to take a couple pics when it gets dark so you can see how they look....
    BTW.... I used the few good bulbs that I pulled off to replace the burned out bulbs in the climate control cluster around the fan speed and function knobs. The bulbs for the temp sliders are smaller. You can get those at Radio shack.
    Ron
    May 2009
    SoCo,MD
    STICKY THIS!!!!!!!! Great directions awesome pics. Makes me want to try it in a different vehicle. again great post
    Dec 2008
    Carthage, NC
    Original post updated with a pic of the gauges at night.....
    Ron
    Apr 2005
    NY
    What color of LED did you use? Cool White or warm white?
    Apr 2005
    NY
    Looks like one LED on lower left corner (Tachmeter) being missed installing.
    Quote Originally Posted by baldd86 View Post
    Dec 2008
    Carthage, NC
    It's there, I just need to check to see if I have a bad solder connection. I will be doing that today.
    Cool white was the only color option for these.....
    Ron
    Dec 2008
    Carthage, NC
    I pulled the gauges out this morning to check that lower tach light and sure enough, I just had a cold solder joint. I resoldered it and everything is good to go now.
    Ron
    Apr 2011
    s. ga
    The cruise control bulb did not come on so how do i could check proper polarity. Thats the bulb to the far left mid panel. Any suggestion? The soldered pad on the bottom is the power pad. But which way to rotate the led bulb is my issue
    Apr 2011
    s. ga
    I just used one of the good regular bulbs and it shines green. Thanks Chevy forum saved me a bundle!!!
    Jul 2010
    rh
    That's awesome man! Some of my buddies used to do this in their cars and I've been wanting to do it in my 08 for awhile!
    '96 1500w/t ChevyZilla's Avatar
    Feb 2011
    WI
    this looks sweet. i think it mite be in order for my truck once the weather gets nicer.
    low n loud 91chvy350's Avatar
    Sep 2005
    odessa, tx
    I was wondering, how the heck did u get the hvac apart?? I got the round knobs off, but couldnt get the temp slider knobs to come off. I have an 05 rst for my daily driver and its came stock with red gauges in the instrument cluster, was wanting to make the hvac red as well
    de pilo pendet .GARY.'s Avatar
    Oct 2008
    Sarasota, FL
    That is a great write up, props to you!! I wanted to do red in mine but never got around to it, wish I had though.
    Aug 2004
    305, South Fla
    hey meanstrk - are you able to dim the lights down at all for night time driving? or are they fully lit the whole time? i've heard people that have done similar swaps and had different results..
    Quote Originally Posted by .GARY. View Post
    you still have your truck?
    71 Chevelle 454
    Dec 2008
    Carthage, NC
    Seriously belated answer, but yes, you can dim them.
    Ron
    Luke GMCTruck21's Avatar
    Apr 2011
    Interwebs
    can you re-up the dead pictures?
    2002 GMC Sierra. ECSB. 5.3 LM7. 4L60E
    totaled 11/25/2012. R.I.P.
