Thread: Advanced timing on 5.7 tbi
Results 1 to 9 of 9
    Apr 2010
    Sulphur, La
    Hey guys I have a 5.7 tbi with a mild rv cam. I haven't felt like it was running right so I advanced the timing a little bit. It's running much better but I'm not sure how much I can advance it without getting premature detonation etc. Any imput would be helpful.
    Thanks, Josh
    Jun 2008
    Union, Missouri
    Re: Advanced timing on 5.7 tbi
    I have mine at 6* with no ill effects and a few guys on here run at much as 12* advanced with a cam and increased fuel psi
    Apr 2010
    Sulphur, La
    Well it's a daily driver so I definately want it to be safe! And I run 89 octane in it at least. I like running premium but gas is sooooo high!!!! 
    Jun 2008
    Union, Missouri
    I hear ya on the gas deal!!!
    But where is the timing now?
    are you running higher fuel psi?
    id say increase it at 2* intervals until you think its going to get as good as it can get. prob 8-10 would be good and safe for sure
    Information Director 1.721afr's Avatar
    Oct 2010
    Altered State
    Eh?..What year?
    Ya we have added a bunch of timing & fuel to crappy .bins, but those are an exception not the rule.
    As always I must insist that just dialing in more advance via distributor position without data interface is a is a BAD idea.
    As a rule you run into the Knock Sensor between 4 & 6* advanced from factory settings.
    I hope your KS functions correctly or you risk major engine damage.
    TBI tuning is a matter far greater than boosting fuel pressure & timing.
    Nutkick?
    Registered User dave w's Avatar
    Jun 2009
    Washington
    Here is a screen shot of my timing table. My timing is set to ZERO. It's AGGRESSIVE! My 93 K1500 - 9:1 / roller cam / 1.6 rocker arms / 454 TBI / Shorty Headers / 3" Single Exhaust / 5.7 liter runs fine with 89 octane using a 180 degree thermostat.
    dave w
    Oct 2010
    north-central PA
    HOLY CRAP that is aggressive, indeed. You run that on stock tbi heads?
    Where are you in WA? Do you do any mountain driving? That's the true test of SA; I've found pinging tends to happen around 90map going up long steep hills...
    I just got my SA to the point where i said "wow! there's my missing 50hp," but damn.. that's a lot of SA. I've got a vortec-tbi, and I'm now thinking I may bump mine a bit further and see what happens.
    Jun 2009
    Washington
    Yes, I use "193" TBI heads. I live close to Mt Saint Helen's, so I routinely see about 6,000 feet (or more) above sea level. The ambient air temperatures were I live rarely gets above 90 degrees F, and the humidity is usually about 70+ % most of the year! I guess the mild weather is why there is huge forest near by me!
    Oct 2010
    sc
    Mine is Around 6. When i up'd it to around 12 it started pinging.
