Thread: engine torque specs and bearing clearence specs please help !!!!!
Results 1 to 8 of 8
    Registered User burnoutcrazy350's Avatar
    Jan 2008
    erie
    Question engine torque specs and bearing clearence specs please help !!!!!
    Hi all i am about to start building my vortec headed 383 stroker the block is going off to the machine shop to get all done today.. what im looking for is were to get all the torque specs and seqences for the hole motor heads,intake, botom end .. pritty much every torque spec i will need to put the motor together .. and i allso need the rod and main bearing clearences for the plastigauge and the crank end play clearence ... if someone could help me out on were to get all these numbers like a book someone makes or anything i would greatly appreciate it ... it is a 4 bolt main 1 pc rear main block that im using
    -Jeremy XLR8N's Avatar
    Re: engine torque specs and bearing clearence specs please help !!!!!
    Do you have a local library?
    Jan 2008
    erie
    Ya we have a big library but i havnt even been in it lol .. why do they probly have a book on everything?
    Oct 2009
    Kansas
    Because I'm feeling generous.
    All in inches
    Connecting rod end play: 0.010
    Crankshaft end play: >0.012
    Camshaft end play: 0.002-0.008
    Main Cap bearing clearance: 0.001-0.002
    Rod Journal bearing clearance: 0.001-0.002
    Camshaft bearing clearance: >0.006
    Torque Specs
    Main Bearing Caps:
    Small Block with two bolt main: 75 ft/lb
    Small Block with four bolt main: 65 ft/lb
    Small Block Rod Caps
    11/32" bolts: 30-35 ft/lb
    3/8" bolts: 40-45 ft/lb
    Small Block Head Bolts
    65 ft/lb
    Small Block Intake Bolts
    30 ft/lb
    All taken from the Haynes Chevrolet Engine Overhaul Manual. It would be a pretty good idea to invest in something like this if you've never put a motor together before.
    If you don't have time to do it right, then you don't have time to do it twice.
    01 ECSB 2500HD 4x4 6.0
    250K and runs like a new truck
    Jan 2008
    erie
    Thank u very much for the specs .... ill have to put a video up of it when i get it all done and in the truck
    OBS'r jsmitty74's Avatar
    Aug 2010
    Midland Texas
    But if your using the Vortec heads, do not over tighten the intake bolts. It will cause damage to the intake gaskets.
    The book says 11 ft lbs on the intake for the small block Vortec, but I always do them in increments, and sequence.
    5 ft lbs, then 10 ft lbs, then 15, then final them at 20 ft lbs
    wah!
    If it ain't a Chevy, or a Peterbilt, it doesn't count!
    1996 1 ton crew, single wheel, 350, 4L80E
    1989 3/4 ton. Parked for good, ready for the salvage yard
    2003 Chevy Venture (wife's)
    Quote Originally Posted by burnoutcrazy350 View Post
    Yes.
    Jan 2008
    erie
    Ok thanks guys im hompimg it all goes together good and runs good im going with an edelbrock cam
