Thread: Strong gas smell out exhaust.
Results 1 to 15 of 15
    Registered User 93 burboun's Avatar
    Nov 2009
    Ocklawaha, FL
    I have a 93 suburban with true dual exhaust with no cats and 40 series flowmasters. I get a really bad gas smell when I rev my truck up while sitting still and sometimes I smell it at other times, but really bad while revving it. Could this be just because I don't have any cats on there? i am getting no codes at all. It has a new engine, it did this with the old engine as well. I think it has the original o2 sensor also.
    1993 Chevy Suburban C1500...5.7
    2006 Ford Ranger XL 2wd...2.3...5 speed
    MI/AZ
    Re: Strong gas smell out exhaust.
    Put the cats back on.
    5TOCK silverado_lover's Avatar
    May 2009
    Galveston, Texas
    Mine is the same way...with a cat.
    Embrace the pollution IMO
    '95 C1500, LT's, 3200 stall, and some PCM tweaking
    Quote Originally Posted by Chevy4life11 View Post
    ive got 8 inches and i still wish i had 6 more
    scotty
    Aug 2010
    lawton, ok
    Quote Originally Posted by silverado_lover View Post
    x2
    1997 ecsb z71 5.7l
    K&N drop in/B&M shiftplus+/dual borla xr-1s
    285/75/16 Cepek mud countrys, DDM 35W 6000k
    alpine cda-117, jl 450/4, jl vr600-csi comps, Kicker L5 8"
    2007 tahoe ltz 2wd bermuda blue
    Fosgate 1000-1BD, (2) sundown SA8s
    ... is OBSessed. Jeff6.0's Avatar
    Elsewhere
    Does it do this when it's warmed up? After the O2 sensors are with-in a normal temp range and go "closed loop" it shouldn't run rich.
    1996 SBSC GMC: 05 LQ4 6.0L, E-Fans, Servo, TCI 3000 Stall, 3.73 14bolt SF, Hotchkis 3/5 drop/sway, Walbro 255, SS Brake sys
    <Thread><Photos>
    1999 2Dr Tahoe:G80, NBS M-Cylinder
    2007 Mini Cooper S
    <Photos>
    Jan 2004
    Dixon IL
    are you sure it's coming from the exhaust and not from the charcol canister? I had something similar years back.
    Nov 2009
    Ocklawaha, FL
    yeah pretty much all the time
    Apr 2011
    arlington texas
    a bad CTS can dump alot of fuel. ohm yours out and compare readings to a new one both while cold. when it happened to me mine ohmed around 5.0 and the new one at the store ohmed about 2.6... fixed my problem. also obd1 was in the 93 and it probably wont store codes so if you get your check engine light to come on leave it running and get it checked.
    Nov 2009
    Ocklawaha, FL
    ummm. what the heck is a CTS?
    Quote Originally Posted by mcoyle05 View Post
    Jul 2010
    Mora, Minnesota
    coolant temp sensor by tstat housing
    Current Ride
    2004 Chevrolet Silverado 2500HD 4x4 6.0L
    Past Rides
    1997 K1500 ECSB Z71 5.7L 350 Vortec
    1994 K1500 ECSB Z71 5.7L 350
    1992 C1500 ECLB 5.7L
    1978 C10 RCSB 5.7L
    1969 C10 RCLB 5.7L
    Nov 2009
    Ocklawaha, FL
    had that replaced when the new engine was installed
    Registered User sussexcounty4x4's Avatar
    May 2008
    Delaware
    if the CTS was bad the engine would cutt off after like 10 min as soon as it gets warm, or make it run rich. had that problem on another truck
    89 Chevy | 358 ci | 0.60 Over-Bore | Forged Aluminum Pistons | ported & Polished 193 heads | Hooker shorties | Custom 2.5 True Duals- 6" glasspacks- 4" slash tips-
    K&N Cold Air | Skyjacker 6" Lift | Mickey Thompson Bajas 35" | AR 17" Bajas | MSD Igniton.
    Registered User 88ChevyLB's Avatar
    Nov 2011
    Fayetteville,NC
    Unhappy Re: Strong gas smell out exhaust.
    Sorry i cant help guys, but I have the same problem. I just put a new 2 1/2" true duel exhaust with no cats and FM 40's on my 88 LB, and it now runs choppy and smells like a gas station. I'm not sure what it gets now but I did get 14 mpg average before. I am wondering if it is running rich? Not sure.. At least it sounds good. Sacrifice.... Any advice?
    Lanark, Ontario
    Primary O2 may not be reaching temp if it is a 1 wire O2.
    But when pulling the cats, expect it to smell some.
    Quote Originally Posted by sussexcounty4x4 View Post
    I've never had a CTS cause the engine to stall out, just run pig rich.
    somewhere else
    There are degrees of how bad a CTS is, usually they go bad gradually. I have in fact had one that was so incredibly bad it would run for a short while then eventually manage to flood the engine because it was dumping so much fuel. When they're reading a false -40F and coolant temp is actually considerably higher (i.e. you're not in the middle of a Minnesota winter) then this is the result. Certainly there are a LOT more marginally bad CTS's out there than outright totally failed ones.
    Richard
