Thread: Replacing hinge pins on 99 Silverado NBS
Results 1 to 14 of 14
    Jun 2008
    London, Ontario Canada
    I've read the sticky and looked at the videos for replacing the hinge pins on the OBS trucks with the single long pin on each hinge but I haven't been able to find anything about doing the NBS with the short pins (2 pins per hinge). Does anyone have any info on doing these? It appears that the nbs doesn't have a hinge spring? Unless I didn't see it.
    Any info would be greatly appreciated.
    Thanks,
    Dave
    1999 Silverado LT 1500 Ext Cab Short Box NBS 5.3 Vortec 265/75/16 Toyo Open Country AT Rear "Super Springs" Blackbear Mailorder Tune
    Jun 2008
    Re: Replacing hinge pins on 99 Silverado NBS
    I finally found some info on how to do this on another site (dieselplace.com) as well as a manufacturers site for an aftermarket pin replacement system.
    Anyway turns out it's dead easy...
    Locate and unplug the connectors for the wiring to the door. On mine there was 2 plugs behind the trim on the driver's side down by where your left foot would be and 1 up in the fuse panel. Once unplugged pull the wires out through the hole. Now undo the 3 10mm bolts. 1 on the strap and 1 on each hinge. On the NBS trucks there is no hinge spring so you don't have to worry about that. Once the bolts are undone and the wires are free just lift the door off and set it aside. It will slide right up and off no problem. I did it by myself. No jack needed.
    The factory pins need to be cut off. I used an angle grinder with a cut off wheel and just cut the bottoms off. Once cut off just bang the old pins out, bang/pry the old bushings out. Install your new bushings and pins. Lift the door back on (again did it by myself no problem, dropped right on). Reconnect your electrical stuff, put your trim back on and you're all set.
    One word of warning I read in the info I found and make sure you remember this because it will be easy to forget. Make sure you at least feed your electrical connectors back through before you close the door. If you don't you'll ruin the connectors for sure by smashing them in the door. The temptation is to test the door as soon as you put it back on. All together maybe 1 hour by myself for both doors. The garage wanted $220 parts and labour to do this. Cost me $20 for parts.
    Hope this helps someone.
    Dave
    Lancaster, CA
    Thanks for the write up. I am sure it will help someone, when they go to do their doors.
    SE Michigan
    sweet, I have never done a gmt800, good info
    2000 Silverado 6.0 4L80E 2wd
    Apr 2005
    NY
    Any link in the dieselplace.com and manufacturers site for an aftermarket pin ?
    Quote Originally Posted by Dave12 View Post
    Anyway turns out it's dead easy..........
    Dave
    Jun 2008
    Quote Originally Posted by JZ57_CN View Post
    No it's a secret...
    Here is the link to the manufacturers site. Not a bad looking product. A little pricey. I'm not sure where they come up with their figures for the cost comparison.
    http://www.totalauto.com/nonmenu/education
    Here is the link to the dieselplace.com thread.
    http://www.dieselplace.com/forum/sho...ght=hinge+pins
    Dave
    Registered User mainechev's Avatar
    Jun 2010
    The Woods
    this should be a sticky
    98 Chevy RCLB K1500, 5.7, 4L60E transgo shift kit, vette servo, 14 Bolt SF, 3.73s, Blackbear 89 tune
    Jun 2008
    Quote Originally Posted by mainechev View Post
    I copied a link to this thread into the door pin sticky
    MN
    I have to do my drivers door the bottom as got some play in it. Nice write up I'll maybe tackle it if I'm up to it.
    2000 Chevy Silverado Z71
    5.3L 4.10's G80
    Jun 2008
    Quote Originally Posted by skierZ71 View Post
    Honestly it's dead easy.
    If I was to do it again I would look for the replacement pin kits that are threaded on the bottom and have a nylon lock nut. Just seems like they would be more solid then the ones with the c-clips. I've seen them at Rock Auto and some of the other on-line parts places.
    Dave
    Not Really Bob
    Newark, DE
    Sticky material...
    The MEAN Helper 99SilveradoNBS's Avatar
    Apr 2012
    Michigan
    Thank you so much!!! I just did this today! so simple the first time I did this i did it with the door on. VERY HARD!!
    | 1999 | Chevrolet Silverado | 1500 | Z71 | 3 Door EXT Cab | 5.3 Liter | 141k | Daily Driver |
    Registered User bulletpruf's Avatar
    Jul 2013
    Naples, Italy
    Glad I found this thread. Need to fix my 99 Yukon.
    Scott
    Registered User Muddi's Avatar
    Nov 2013
    Louisiana
    So is there videos? Or pics?
