Thread: Truck Surging Idle in Drive while stopped...
Results 1 to 13 of 13
    May 2008
    Auburn
    It surges from about 300-600 rpms only in drive at idle, such as stopped at a red light. I read somewhere that it may be the distributor. Any truth to this? If so, how do I check/fix it?
    Thanks,
    Matt
    01 RCSB Z71 leveled on 285's. Stock for now.
    Dec 2010
    Virginia
    Re: Truck Surging Idle in Drive while stopped...
    What year if it is a 96 up ... could be mass air flow sensor.
    Clean it see if it helps.
    Dec 2008
    NEW JOISY
    My truck did that and after replacing a bunch of things I finally figured out it was the fuel pressure regulator,the diaphragm was leaking.
    Mar 2011
    Pensacola, FL
    Try cleaning/ replacing the idle air control, on my 97 it would only surge with the a/c on and I replaced the iac and problem solved
    1997 RCSB Z71 5.7 Vortec, 411 PCM , Ultra gauge, SS Headers, EGR Delete, Magnaflow Hi-flow cat assembly, Cat back with flowmaster 40, Transbuilderguy Built 4l60E, Yukon Duragrip Posi 3.73, 33 x 12.5 Maxxis Big Horn
    May 2008
    Auburn
    Its a 97. I just cleaned the MAF, but dont have time to drive it tonight. We will see in the morning if that was the culprit. I hope so. The screen was dirty but not bad. If it keeps surging, I'll have the shop look at it.
    Thanks
    Matt
    Jul 2010
    santa paula
    my truck does this . all started after the tune .
    1996 ecsb z71 3.73 g80 5.7 b&m shift improver , vette servo , 30k cooler , 7 quart huges trans pan circle d 2800 stall,160tstat ,k&N intake , ceramic coated eddlebrock headers. true dual flowmasters 2.5 inch and H pipe black bear 91 tune .and a frantz bypass oil fitration kit, 125 hp wet nitrous
    May 2008
    Auburn
    Still doing it. Tech at work said it sounds like a vacuum leak. He's gonna look at it on Monday.
    Thanks
    Matt
    May 2008
    Auburn
    Scanner said MAF is not functioning properly. Tech said the truck is running very rich. Does this make sense? Would a MAF sensor on the fritz make the idle fluctuate only in drive? Is there more?
    Matt
    yeah it makes sense
    Matching Ninja 500r
    May 2008
    Auburn
    Swapped in another MAF from a different truck and brought it home... still doing it. Any other thoughts guys? I doubt both of us have bad MAF sensors.
    Thanks
    Matt
    Dec 2010
    Virginia
    Said it is running rich.. maybe coolant temp sensor... or 02 sensor.
    Sometimes will not bring a code. A bad map or loose vacuum will cause surging.
    97 vortec common issues: maybe leaking fuel poppets or fuel regulator. intake gasket, poppets ever replaced?
    Matching Ninja 500r
    Whats that smell? cruizerman's Avatar
    Bow Chica Bow Wow
    Yes, I know this is an OLD post, but I'm having the exact same issue on my 99 OBS K1500 tahoe. It's happens every couple of stops while in D at a stop.
    To the OP, did you ever figure out what caused your issue?
    '03 Chevy SCSB 4.3L FOR SALE!!!
    '99 Chevy K1500 4D Tahoe SOLD
    '08 Buick Enclave CXL
    Suburban coming soon!
