Thread: Check Engine Code PO128 (Coolant Low Temperature) 04 Silverado 4.3V6
Results 1 to 13 of 13
    Aug 2009
    Minneapolis, MN
    Anyone have experience with Code P0128?
    Partially stuck open thermostat seems likely, or the coolant or intake temperature sensor.
    This is the list of suggestions:
    * Low engine coolant level
    * Leaking or stuck open thermostat
    * Faulty cooling fan (running too much)
    * Faulty coolant temperature (ECT) sensor
    * Faulty intake air temperature (IAT) sensor
    2004 Silverado 1500 Work Truck
    4.3 Liter V6 - 5 Speed
    Re: Check Engine Code PO128 (Coolant Low Temperature) 04 Silverado 4.3V6
    so is it low on coolant?
    Matching Ninja 500r
    Old Man Mountain Swaggerwagon's Avatar
    Tennessee
    what is your temp gauge reading..?
    if it's reading normal...them i would suspect the IAT sensor...
    Aug 2009
    Minneapolis, MN
    Coolant is not low, and the dash gauge shows the operating temperature to be 185 F. Ambient temperature range here has been 30-40 F, warm compared to the Minnesota winter we are trying to close out (snowed again yesterday).
    Registered User hadfield's Avatar
    Jan 2007
    pa
    about 35 k miles ago-
    had same code on my 06 - changed temp sensor-
    SE Michigan
    first, replace the thermostat, this is the #1 cause for this code
    2000 Silverado 6.0 4L80E 2wd
    Aug 2009
    Minneapolis, MN
    Is the temp sensor the same sensor that provides the signal for the dash temp gauge? My dash temp gauge shows an operating temp of 185, which is where it has always been, following warm-up.
    Aug 2009
    Minneapolis, MN
    I finally got around to replacing that thermostat. It had been awhile since I had done a thermostat; it was back when a radiator had a cap and a drain. It was a bitty messy, as the coolant splashed off the frame and into a pan and onto my driveway. I got the new thermostat installed, and now my temperature gauge reads about 200 following warm-up (formerly 180). However, I am not getting any additional heat into the cab. Is it possible I am not getting coolant into the heater core? I checked the lines for a valve, but found none. Do I need to purge air? The coolant level has not gone done since I first filled it.
    Apr 2006
    IN
    You've likely got air in the system. Sometimes it takes a heat cycle or two to get it purged but shouldn't be a major issue
    Quote Originally Posted by gmcman355 View Post
    also flush the heater core.
    Matching Ninja 500r
    Aug 2009
    Minneapolis, MN
    I have been driving it a couple times a day for about a week, so its seems unlikely to resolve on its own. How do I flush the heater core?
    Sep 2014
    SE PA
    Quote Originally Posted by rose359 View Post
    Bump, how DO you flush the heater core?
    Aug 2009
    Minneapolis, MN
    Quote Originally Posted by Redskins13 View Post
    I think that the easiest way will be to back-flush the whole system, installing one of those Prestone kits that splices a hose connection into one of the heater core hoses.
    I am getting enough heat to defrost my windshield when it is below zero here in Minnesota. However, the air coming out of the heater vent does not feel warm. I keep the fan speed low because it isn't sufficiently warm to have it blowing on me. Since I replaced the thermostat in November, I have lost hope that the issue will resolve on its own.
