Thread: Engine Temp Gauge
Results 1 to 9 of 9
    Apr 2011
    Kansas
    Engine Temp Gauge
    I have a 94 Silverado 4x4 with a 5.7 litre V8 engine. The temp gauge has began to fluctuate consitantly and when it hits the "peg" or top of the gauge the check engine light comes on. Is this possibly a faulty sensor? If so where is it located on the engine? Or is it in the gauge itself? I've heard that if it is the gauge, then I have to replace the entire panel not just the gauge, which is very expensive!? Thanks for any and all help.
    Nov 2008
    Re: Engine Temp Gauge
    U can try temp sensor...its on the intake next to thermostat housing...on left I believe...mine was cracked...
    Jul 2010
    Mora, Minnesota
    Quote Originally Posted by 2000Chevy4x4 View Post
    Not quite right. The sensor by the T-stat housing is for the computer only.
    The sensor for the guage on the dash is in the drivers side cyl. head. I believe its a one wire connector.
    Also when you say "fluctuate" do you mean it does it slowly or just randomly jumps around quick???
    Current Ride
    2004 Chevrolet Silverado 2500HD 4x4 6.0L
    Past Rides
    1997 K1500 ECSB Z71 5.7L 350 Vortec
    1994 K1500 ECSB Z71 5.7L 350
    1992 C1500 ECLB 5.7L
    1978 C10 RCSB 5.7L
    1969 C10 RCLB 5.7L
    OBS'r jsmitty74's Avatar
    Aug 2010
    Midland Texas
    Yeap, between number 1 & 3 cylinder
    wah!
    If it ain't a Chevy, or a Peterbilt, it doesn't count!
    1996 1 ton crew, single wheel, 350, 4L80E
    1989 3/4 ton. Parked for good, ready for the salvage yard
    2003 Chevy Venture (wife's)
    Jul 2010
    Mora, Minnesota
    yeah thats the one^^^^^^^
    Current Ride
    Past Rides
    1978 C10 RCSB 5.7L
    1969 C10 RCLB 5.7L
    Apr 2011
    Kansas
    Quote Originally Posted by 1994chevydriver View Post
    Thanks for the info! I mean it bounces from the bottom to top and back, (cold to hot to cold) very quickly. Sometimes it will max out and quiver there and other times it will just quiver at the running temp. When it is hitting the top I notice the engine runs a little rough or misses a little. I didn't mention anything bout it running rough before.
    Again thanks for your help. I hope this is what the problem is.
    Apr 2011
    Kansas
    Hey man, thanks for the pic it is a huge help. Hopefully that is the problem!
    Aug 2010
    Midland Texas
    Disconnect the sensor,pictured above, see if the gauge still malfunctions. Yes, you can run it without it.
    wah!
    Apr 2011
    Kansas
    Quote Originally Posted by jsmitty74 View Post
    Will do. Thanks a ton!!!
