Thread: Tow mirrors with led running lights......
Results 1 to 17 of 17
    Central NC
    I have these:
    http://www.am-autoparts.com/2004/GMC...-13511626.html
    on:
    ^See the amber marker on the side? They light up with the turn signals...
    My question, has anyone wired them to also come on with the running light? What wire to I splice into? Do I take the turn signal wire from the mirror and run it to the turn signal/running light up front?
    Midwest FSC Chapter!!
    Illinois
    Re: Tow mirrors with led running lights......
    i know 88gmctruck has a pic of the wiring he did with the diodes and stuff to make the lights work on his mirrors with the running light and turn signal
    check it out
    cant be to much different for the nbs trucks
    97 z71,3" body lift, tow mirrors, cranked and AAL, 35" KM2's, 4.56 gears w/lockright, 6k HID's, strobes/lightbar/leds
    06 2500hd 6.0 gasser, 4" lift, 37" Toyos on 20" rockstars, 20" lightbar behind grill, colormatching in progress
    Central NC
    I dont know, I just looked, he had wire in everything on his. I might try it with a 5 amp fuse inline and see what it does. It should work as long as its getting 12V, might have to put a relay in there. I'll figure it out.
    Illinois
    check out this
    this is just the wiring thing he made up so the lights work with parking lights and turn signal
    Quote Originally Posted by 88GMCtruck View Post
    After multiple people asking how to wire the LEDs in as signal and parking lights, I FINALLY had enough time to draw a wiring diagram. If you can't figure it out from here, there isn't really much else I can do. You'll need 4 diodes for each mirror, and 12v+ from the parking lights and each respective signal 12V+
    Basically, whichever circuit is de-energized acts as the ground circuit, if both are energized they have no ground and the light turns off. Both the parking and signal circuit have a floating ground when off, hence how the light can utilize this wiring to function. It's exactly how the front 194 marker light is wired.
    Central NC
    Somehow I totally missed that diagram.
    Illinois
    thats what i was trying to tell you to look for
    i dont remember what page that was on in his thread though
    it pretty much describes and shows you how to wire it up with some diodes and stuff so that they work both ways
    Central NC
    so from what im seeing.....
    Parking 12v goes to diode 12v+ for LED and LED ground. Same for signal 12v+???
    I think I can figure that out!
    Illinois
    pretty much one uses the other ground so you put diodes in them so that it can work like that pretty much
    Nov 2002
    ohio
    so has anyone done this yet? I've been kicking around the idea and just stumbled across this. thanks chris
    also do they offer replacement lights for these when they go bad or if we fry them.
    Central NC
    I havent felt like fvckin with it. 2 of the LEDs have burnt out (one on each side) and I'm thinkin of changing them to some hyper bright amber LEDs and I'll tackle it then.............not sure when that will be tho.
    Nov 2002
    ohio
    Just did mine today, tied them in to the front corner marker/turns. mirror turn signal now only works when the marker lights are on. I just bought 25 feet of the 2 wire in a grey loom/shield from napa, worked out great. Drivers side I ran it through the firewall where the wiper or cruise wires go ( cant remember) but its right under the brake booster. passenger side is a little trickier since there are no wires going through firewall on that, I just ran it up along the fender and brought it out the back side of the fender where the door is and ran it through the door grommet. I did notice on the drivers side the plug that controls the turn signal has 3 wires. a black (which i believe tested 12V)and a blue and brown wire which is for the turn signal. the other passenger side harness plug has a brown wire. you have to use the blue wire from the second plug (must just be how the switch circuits are wired). I just cut the wires and used butt connectors. I didn't take any pics of the install. but i can get some of the wire routes if needed.
    Registered User crushor's Avatar
    Jun 2010
    midwest
    Squeaky, are those NNBS tow mirrors on an OBS? I would like to know how you did that. How is the fit from mirror to door? Are there any issues? Thanks.
    '99 Chevy Burban, 2007 Ford F-250 Harley-Davidson edition Powerstroke, 1988 Ford TBird 5.0L, 2012 Sure-Trac 18' Dovetail Car Hauler, 1987 Mustang 5.0L.
    Illinois
    yes and no
    they are the gmt800 mirrors but on a base made for the obs trucks
    there are from a seller on ebay, they are the only ones that make the tow mirrors for the obs trucks like this
    Jun 2010
    midwest
    Squeaky...one last thought on your mirrors, do you remember the seller on Ebay with those mirrors/mounts for the OBS? Thanks again.
    Illinois
    optionracing was the seller i got mine from
    you can get anything from the all manual to ones with signal to the power heat and signal like i got
    May 2008
    richmond, va
    they work good too.. i love mine
    still wonderin if i can just run the signal wire up front where i taped into the corner light when i added the upper corner lights if it will work that way?
    95 4x4 tahoe- was-2 inch crank block 3inch body lift 35 bfg m/t. 102ss whip with cobra 19.
    in the works- no bl sas 10 bolt front 35s 91 np241c
    http://www.cardomain.com/ride/3856942
    Oct 2011
    Rhode Island
    I have those same led tow mirrors but mine were simply JUST for running lights. I could hook them up to my turn signals too but i havnt had the motivation too lol.
