Thread: A/C not blowing air....blower motor need replaced?
Results 1 to 9 of 9
    Apr 2010
    Stillwater, OK
    Hey guys. Been on the forum for a while but tend to be more of a lurker but was looking for some advice. I drive a 2005 Chevy Silverado Z71. Recently, the A/C has just quit blowing air. It will occasionally come on but does not blow very strong. Still having condensation, just no air. Any suggestions?
    Unofficially Official Heavy_5.7's Avatar
    Sep 2005
    Midwest, USA
    Re: A/C not blowing air....blower motor need replaced?
    "Recently, the A/C has just quit blowing air. It will occasionally come on but does not blow very strong. Still having condensation, just no air."
    Kind of difficult to follow whats happening, can you explain the problem a little better?
    Everyday is Monday, except Friday.....
    SE Michigan
    if the blower is not blowing, check for power and ground at the blower motor
    2000 Silverado 6.0 4L80E 2wd
    Apr 2010
    Stillwater, OK
    I apologize, should have been more clear. It is like my A/C system itself is working but the blower motor is not coming on. I do not get any air out of the air vents, nor the defrost vents. I have checked the fuses, I will be looking into checking the wiring on the motor tomorrow.
    SoCal
    Does the blower work when the AC is off... just heat or vent?
    First thing is check the power connector on the blower for power. Check the condition of the connector... mine was very loose, so I replaced it when I replaced my blower.
    1995 Suburban 1500 2wd
    Apr 2010
    Stillwater, OK
    Pulled the blower motor today and hooked up some jumper wires to it and it came right on. Looks like it is probably the blower motor resistor. Thanks for the help.
    Apr 2010
    Stillwater, OK
    Tried a new resistor today and still didnt fix it. Any other suggestions would be great guys. Thanks.
    Jun 2011
    Spanaway, WA
    If all fuses are good and the resistor is not the issue then it is usually the control switch. Just out of curiosity do you get fan action when the AC is off? or none at all?
    If none at all then see about a set of controls from a wrecking yard. I am assuming you have the manual controls for your truck and not the digital auto controls. If you have the auto ones get it off auto mode it never seems to know what you want just what it thinks you want.
    Massey
    A Veteran is some who at some point in his or her life, wrote a blank check to the government for any amount up to and including my life.
    Remember Freedom is never free.
    KG7NQY
    Apr 2010
    Stillwater, OK
    I have the auto controls. Does not come on when turned off. I tried it with the auto, as well as just turning the fan up. Neither worked.
