Thread: 5.7 vortec cam swap
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    Registered User Vortec 5.7's Avatar
    Jun 2010
    Houston
    5.7 vortec cam swap
    im cammin my truck soon,nothing crazy just a small cam......anyone knows if its hard?
    May 2010
    Deland, Fl
    Re: 5.7 vortec cam swap
    gotta rip apart the whole front end of the motor.
    '94 GMC C1500 RCLB, DD - Sold
    Registered User skylark's Avatar
    Oct 2008
    Grants Pass, OR
    Not trying to be a jerk. If your asking this question then you have a ton a research to do. This sounds like it may be beyond your current skill level. Use the search button here. You should also buy a manual to have on hane for when you do the job.
    All of that aside, these are the things I can think of off the top of my head that need to be removed to do the job.
    Air filter assembly
    All of the wiring on top of the engine
    Serpentine Belt
    Water Pump
    Fan shroud
    Radiator
    A/C Condenser
    Grill
    A/C Compressor
    P/S, A/C Bracket (you can leave the P/S pump on)
    Alternator
    Fuel lines
    Distributor
    Throttle cables
    Exhaust pipe
    The crappy heater hose quick connect (replace with the dorman unit)
    Intake manifold
    Valve covers
    Rocker arms
    Push rods
    Retainer plate
    lifter guides
    Lifters
    Crank Pulley
    Balancer
    Two oil pan bolts
    Timing cover
    Reluctor
    Timing Chain
    Cam
    I know I'm missing something in there. You should replace the timing chain while you have it apart. Also keep in mind that it will need to be tuned and the A/C needs to be serviced properly (vacuumed) rather than just a simple recharge because you had the system open. Oh, the gaskets to use on the intake are the MS9800T from Fel Pro. You might want to consider the mpfi conversion as well (Delphi FJ10566).
    89 GMC Stepside 2WD 4/6 drop, working on the stroker again!!!
    Y2K Chevy K3500 CCLB Dually 6.5, the Black Pearl.
    Jun 2010
    Houston
    Quote Originally Posted by skylark View Post
    Air filter assembly
    Serpentine Belt
    Water Pump
    Fan shroud
    Radiator
    A/C Condenser
    Grill
    A/C Compressor
    Alternator
    Fuel lines
    Distributor
    Throttle cables
    Exhaust pipe
    Intake manifold
    Valve covers
    Rocker arms
    Push rods
    Retainer plate
    lifter guides
    Lifters
    Crank Pulley
    Balancer
    Two oil pan bolts
    Timing cover
    Reluctor
    Timing Chain
    Cam
    im not sure wat my skill level is but in done all the mods so far my self
    MODS
    ported throttlebody
    pulleys
    1.6 rocker arms
    mid tube headers
    swapped rear end for a posi
    e-fans
    shackles and hangers
    oh i didnt install my drop springs and vette servo....but then again i didnt have the tools back then
    i bought the haynes book when i was installing the rockerarms
    wat is mpfi conversion?
    Registered User loudandproud's Avatar
    Mechanicsburg PA
    Its not all that hard, just time consuming and its more expensive than original anticipated.
    If your gonna cam it you mine as well do it for real...
    Yank the heads, have em milled .035", Install comp 26918 springs with 787 retainers and +.050" Valve locks, pin the rocker studs and throw on
    decent roller rockers.
    Reinstall with .015" steel shim, puts you at around 9.8:1 compression...
    Throw in a good roller... CCA-08-300-8 would be good for a truck with a stock stall...
    Honestly a cam swap isnt worth it unless you go big. Headers, Stall, plenty of compression... yada yada
    10 horse power, schmaybe 15 if you play it conservative and just do the cam swap vs. 100+ for the works.
    BUILT NOT BOUGHT...
    Jun 2010
    Houston
    Quote Originally Posted by loudandproud View Post
    i bought a cam and another set of vortec heads with bigger springs,locks and retainers for 150.00 used from a good friend
    Mechanicsburg PA
    Quote Originally Posted by Vortec 5.7 View Post
    wow! are you serious? you stole that ****! Good JOB! hhaah...
    What cam and valve springs did you get?
    PS. Does you friend have any other items he wants to sell for those prices haha
    BUILT NOT BOUGHT...
    Jun 2010
    Houston
    im not sure on the springs,he said that it has a 550 lift limit
    cam spec are .480/.480.....210/220 dur.....264/274 avd....lobe sep 112.....
    lol thats all he had forsale.....he gave me a cracked rollpan......but ima fix that first before i install it
    Mechanicsburg PA
    oh ok youre good there. .480 should be pretty safe. More than likely if he went through the heads he addressed the retainer to valve seal clearance issues.
    i suggest if your swapping heads you spend the $100 bucks and get em shaved at least .030 and take out some head gasket.
    run the number and shoot for around 9.8 or so...
    would hurt to find the abdc of that cam and check your dynamic compression ratio. shoot for about 8.5:1 for 93 octane or around 7.9:1 for 87 octane.
    BUILT NOT BOUGHT...
    May 2009
    Dallas
    I think that's the same cam I installed and it's modestly better than the standard vortec cam.. a little better bottom end, but that's about it.
    You may not have to rechip.
    Jun 2010
    Houston
    Quote Originally Posted by para driver View Post
    thats it? no topend gain?
    i need more than A LITTLE gain....its not worth my time.....ill just sell it then
    Proud chevy owner
    Salt Lake City
    It should improve top end too, it's more lift and longer duration than stock cam specs
    awesome sig(s) xZoomerZx!
    1996 silvy, 6"bds, sf14bolt, eaton elocker, precision 4.56s, 37" claws;
    383ci vortec, compcams 218/224 .495"/.502" 110*;
    longtubes, magnaflow exhaust, 0411
    2006 Infiniti G35 - dropped on coils, bottle-fed
    Jun 2010
    Houston
    ok,well ill start the swap tomorrow then
    May 2010
    Deland, Fl
    if you wanna sell it, ill take it.
    "Just Harry" TheJavelin's Avatar
    Jan 2010
    Powder Springs ,GA
    Good luck
    I Liek NBS
    Bowties and Guitars
    Crosby TX
    You didn't get that cam from SSean did you? i know he still had that built 5.7 when he took it out for the 6.0 swap
    6.0 Killer
    lm7 w/ TBSS topend, milled/ported 243's, 92mm tb. yank 3600 stall yukon 4.10:1 gear, assassin tractionbars, eaton locker, hoosier 27" slicks, tr 220/220 dyno tuned by flaco-- 12.92 @ 104 mph 1.67 60ft.- SOLD
    99 T/A WS6 Built Forged Iron block 370 on Spray Tuned by me
    Jun 2010
    Houston
    Quote Originally Posted by GreenVortec View Post
    no he sold motor with everything......and the cam he had was 224/236 and 500/510 lift......some thing like that
    Jun 2010
    Houston
    Quote Originally Posted by TheJavelin View Post
    Good luck
    thanx
    Bowties and Guitars
    Crosby TX
    ahh.. if i didnt do my swap i would of bought that bad boy from him..
    are you the blue extended cab?
    6.0 Killer
    Jun 2010
    Houston
    he ran 13's with that motor.......I have a green truck with tan designs..........
