Thread: Recommendations for Vortec 5.7 spark plug wires?
Results 1 to 20 of 33
    Old Newbie Idowa's Avatar
    Oct 2003
    Northern AZ
    I installed a set of the Summit Racing $30 wires, MSD Cap and rotor, and NGK U-groove plugs when I first bought my Suburban a year ago.
    It has been getting more and more sluggish lately and yesterday I did a redneck dual exhaust so I could actually hear the motor(cut the muffler off and installed 2 glasspacks w/ no tailpipes for now).
    Yep, it has a slight miss that seems to come and go at different RPMs; sometimes it will idle rough and other times it will only start running rough when I go up in RPMs. The motor will even cut out at freeway speeds every now and then...
    I thought maybe a weak coil, so I installed an Accel coil yesterday and no change.
    I've cleaned and de-screened the MAF and replaced everything in the ignition system, so I'm left with the possibility that the ignition wires may be causing issues. I noticed the Summit wires didn't fit very well and I wasn't able to route them properly.
    I'm thinking about upgrading to a higher end wire and was wondering what are some of the ones you guys have run with good results...
    `97 Suburban K1500, CAI, Custom roof rack, pocket fender flares, 33x10.50 BFG ATs on 15x8 Mickey Thompson rims, 1.5" torsion bar crank...
    Registered User 1990 GMC's Avatar
    Mar 2011
    Maine
    Re: Recommendations for Vortec 5.7 spark plug wires?
    Try checking the timing
    Lanark, Ontario
    AC delco wires.
    Aug 2008
    KENTUCKY
    Descreening the Maf is going to hurt performance. Plug wires are strickly preference as there all so close in performance, when using the good brands. Same with plugs, cheap copper plugs (ngk) work great for me.
    Oct 2003
    Northern AZ
    Quote Originally Posted by kemble View Post
    It didn't on the last Vortec I owned and didn't on this one either...
    Aug 2008
    KENTUCKY
    So do you have datalogging information to back your descreening Maf idea? Cause I have seen datalogging with it descreened and it indeed hurts performance.
    Aug 2001
    New Jersey
    Taylor Wires, Factory platinum plugs and Delco cap and rotor.
    FastOrange BlacK20's Avatar
    Nov 2010
    Williams Lake, BC!
    Quote Originally Posted by CKTA View Post
    Lanark, Ontario
    Taylor makes one hell of a product at a fantastic price point. Just put some on my 07, quality stuff.
    Oct 2003
    Northern AZ
    I was just checking them out on Summit; I'll have to screw around some more with the Summit wires before I pull the trigger, but Taylor looks like what I'll be going with...
    Aug 2001
    New Jersey
    SE Michigan
    agreed, the screen is there to straiten out the air so volume is measured correctly
    2000 Silverado 6.0 4L80E 2wd
    RAGMC ragmc's Avatar
    Dec 2004
    Gilbert Az
    MSD cap rotor MSD wires
    Lanark, Ontario
    Quote Originally Posted by ragmc View Post
    May Suddenly Die. MSD left me walking twice, Accel once. They'll never get a dime from me again.
    Nov 2010
    Williams Lake, BC!
    I had a 100% new MSD dizzy, started truck up once, and coil died, no joke.
    Slapped a OEM HEI that had been sitting on the shelf for 15 years, drove truck for months.
    Nov 2010
    Williams Lake, BC!
    my dad used a set on his camaro for 10 years, still looked new when he replaced them.
    Maine
    For plugs, AC Delco only. Wires, AC Delco or Napa's Blue Max by Belden.
    I'm thinking the screen on the MAF is there for a couple reasons. Most importantly, straighten airflow for proper readings - as mentioned. Also, it would protect the MAF from debris.....
    Jul 2011
    Virginia
    AC Delco plugs and wires, they fit right and get the job done at the end of the day. If you want aftermarket I would go with MSD. They make wires for 8,000 hp top fuel dragsters that are running ignitions with enough power to light your house up. Check everything first, you may have another engine related problem i.e. fuel filter, egr, injection spider, etc. I have seen too many aftermarket parts that are of poor quality, alot of them are sold with "romance" and "you need this" advertising.
    Mar 2003
    West Michigan
    Delphi wires (or anything else they make)......... look the number up on the Delphi website, and then do a search on Amazon for them. They will be the OEM wires....... probably the same as AC Delco, but not necessarily. Delphi has lost business to other companies such as Denso, so newer GM vehicle have less Dephi content, but for the GMT-400's Delphi makes a lot.
    Several years ago I bought a set of AC Delco wires on ebay for cheap and stored them until I needed them. The seller bought them, and then sold his Suburban.
    454cid
    1999 K3500 RCLB
    Registered User MaDeNMiAMi305's Avatar
    Leisure City, FL
    msd 8.5mm super conductors and msd cap and rotor while your at it.
