Thread: Coolant Leaks from 5.3 heads
Results 1 to 5 of 5
    firemandad1975
    Oct 2009
    Gilbert, AZ
    I have 2 leaks on my 2000 Chevy Suburban 4x4 5.3liter. They are at the back of the engine toward the firewall. They appear to be coming from the head bolts or head to block mating surfaces. It's only at the rear of the block, but leaks consistently when hot. Short of removing the heads and replacing the head gaskets, anyone have any ideas? It has over 160k miles and we are just trying to make it last.
    Re: Coolant Leaks from 5.3 heads
    maybe head gaskets or cracked heads.
    Matching Ninja 500r
    Mar 2011
    California
    I agree. There is not a whole lot to be done here other then investigating further.
    Auto Zone along with the others sell a sealer you put in that is suppose to fix a head gasket leak. but that is a shot in the dark IMO.
    I would bust out the Haynes, brush up on FSC, and get those heads taken off to see if the gasket just needs to be replaced.
    What color is the exhaust coming out of the pipe?
    Feb 2005
    Torrington, CT
    There is a small metal coolant line, I think they call it a steam vent for the heads. It goes from the front of the heads to the back of the heads, its under the intake manifold and is held down with small bolts and uses o rings to seal it. I would check that out first before you put any sealer in it, or pull the heads. Its easy enough to pull the intake and check that line out first. Good luck.
    2005 GMC Yukon SLT. Black 5.3. Airaid cai, Gibson dual cat back, led taillights, smoked 3rd brake light, billet grille
    Mar 2011
    California
    IMO the steam vent would be easily traced back to the busted O-ring.
    It sounds from his description it was coming directly from the head gasket.
