Thread: water pump leaking what to do
Results 1 to 18 of 18
    Jun 2010
    Maine
    i see that my water pump is leaking but my truck doesnt over heat so should i replace the whole pump or just the seal
    86 chevy k10, 4" suspension 3" body lift, in restoration right now
    chevy guy
    Oct 2009
    katy, tx
    Re: water pump leaking what to do
    well the problem ive run into when coolant is leaking from the weap hole on the pump is that the bearings in the pump are going out. ive replaced the pump and had no further issues. i installed a stewart stage 2 water pump on mine for more flow and havnt had any cooling issues since
    92 Chevy C1500 5.7 263k miles
    94 Blazer K1500 with a 6.5L turbo 164k miles Elite 2dr Tahoe owner's club #18
    95 Suburban C2500 6.5L turbo 295k miles:fsc:
    Jan 2004
    Dixon IL
    more that likely it is coming from the weep hole, replace the hole pump, they are cheap
    Aug 2010
    Missouri
    A rebuilt pump is like 18.00 from oriellys. Replace.
    A word of advise though, those pumps aren't coated even if they look like they are. I threw mine on bare and it rusted in a week. Throw a coat of paint on it. And make sure you keep the pulley studs and any fittings from your old pump.
    1995 Chevy Cheyenne 2500
    RCLB 4x4 (Prev. 6.5 diesel)
    NV4500, 14 bolt FF 3.73
    Rebuilt 350 4 bolt main
    Summit Racing K1102 Cam
    906 Vortec Heads
    Single 3" exhaust with AM Y-pipe and Cherry Bomb Extreme
    Edelbrock 1406, Summit Stage 1 Intake
    Jun 2010
    Maine
    sweet guys thank you very much it doesnt look like it should be to bad to change either.... trucks a 2000 with the 5.3. thanks again
    Mar 2003
    West Michigan
    I wouldn't buy the cheapest pump you can find. You may end up changing it again in 6 months.
    +1 on the paint. It'll look so much better that way.
    454cid
    1999 K3500 RCLB
    Jun 2010
    Maine
    ya i was gona go see how much it was at the dealer first
    Aug 2010
    Missouri
    Quote Originally Posted by 86liftedk10 View Post
    I though you were talking about the truck in your sig. On a newer model I'm sure the pump will be more expensive.
    906 Vortec Heads
    Appleton, WI
    Right around $85-$100 for a rebuilt pump. I had a similar problem, the pump wasn't leaking out of the shaft or weep hole it was leaking out of the impeller cover on the back of the pump. Swapped it out with a parts store reman unit. Got just about a year out of it and had to change it again, this time it was coming out of the weep hole. Glad it was warranted. But the new pump comes with both gaskets and the thermostat oring. Doesn't take long depending on how mechanically inclined you are.
    Jun 2010
    Maine
    Quote Originally Posted by 88Chevy350 View Post
    sorry for the confusion i keep meaning to update my sig.... ya i watched some dude on youtube do it and it didnt look that bad at all
    Registered User Ghastlyone's Avatar
    Las Vegas
    Quote Originally Posted by MrGiggles View Post
    Worst advice ever.
    Don'y purchase any of that refurbished **** from Auto Zone, Oriellys, etc.
    Get an AC Delco, and be done with it.
    Mar 2003
    West Michigan
    Quote Originally Posted by Ghastlyone View Post
    Worst advice ever.
    The AC Delco will probably be refurbished too........ my alternator was. It will hopefully be better rebuilt than some others, Though.
    454cid
    1999 K3500 RCLB
    Mar 2003
    West Michigan
    If the LS pumps are anything like the traditional SBC and BBC pumps I wouldn't replace it if it's just the back cover........ I'd just replace the back cover gasket.
    454cid
    1999 K3500 RCLB
    Las Vegas
    I've been down that road of buying parts like water pumps, alternators, etc. from Auto Zone.
    I bought a water pump for my tuned port motor back in the day from Auto Zone. Installed it, and literally, it was leaking worse then the one I took off.
    I've yet to have an issue with Delco products.
    Aug 2011
    Gilbert, AZ
    My Autozone pump has been on my truck for 5 years now. Just DO NOT BUY THE REBUILT PUMP!!! If you look closely at many of these rebuilt pumps, you will see that the housing has been ground down where the radiator hose attaches. It leaves the housing VERY thin. They can rot through quickly at that point. A new pump gets you an entirely new housing. That's what I installed. Plus, I got a lifetime warranty on it. Delco won't do that. However, they DO make a good pump. On my truck, the original pump actually had a whole in the back plate. It wasn't leaking at the seal.
    Aug 2010
    Missouri
    Worst advice ever.
    That 18.00 pump has been on for almost a year now and I haven't had an ounce of trouble with it. I was strapped for cash at the moment so I went with the cheapest option possible, looking back I would have gotten the lifetime warranty that was a few dollars more.
    906 Vortec Heads
    Dec 2009
    Virginia
    Just my two cents. Water pumps are the one part from the parts chains I haven't had problems with. I've replaced a few beginning with my first car, a 76 Delta 88. Their rebuilt starters and alternators are dog****, but they offer new stuff that works pretty well. The problem is they don't stock new stuff much, and if you're in a pinch, you're stuck with rebuilds. Go to the stealer, uh I mean the dealer for more sensitive parts, but a simple water pump from autozone should be fine.
    Sep 2006
    Tennessee
    +1 on painting it.
    I also used studs and nuts to install it. It made it much easier to get the gaskets on without sliding out of place while fishing for the bolt hole.
