Thread: HEY ALL! OIL PUMP 97 chevy truck fullsize
Results 1 to 15 of 15
    Burnsville
    Do you need to lift the engine up to replace a oil pump on a 97 chevy silverado z71.
    Is there any alternative ? Thanks.
    Stuck in Ohio. NeverFastEnough's Avatar
    Aug 2010
    Wisconsin
    Re: HEY ALL! OIL PUMP 97 chevy truck fullsize
    You might be able to do it with the motor in the truck but it's going to be a pain in the a$$ I bet (and just because you might be able to do it, doesn't always mean you should) lol. I think I'd just pull it and check everything out instead of just the pump if the pump went out you know? Plus it's way nicer working on something on the stand.
    SW OH
    In that motor, the oil pump basically NEVER goes bad.
    What's the real problem? Better to start with that, than jump directly to something time-consuming and futile.
    Mar 2011
    Pensacola, FL
    DONT PULL THE MOTOR, the oil pump plastic collars are notorious for cracking and breaking .....pull the passenger side 2 bolts holding the front axle tube up, unbolt the exhaust and remove it, take the dust cover off of the transmission , and whatever else is in the way....pry down on the mounting flange and once you unbolt the pan it will pretty much hit you in the head falling out probably missed a thing or two but once you get under there you will see what needs to come off...good luck I did mine in 2 hrs taking my time and using air tools...put a high volume pump back in it and the steel drive shaft for it DO NOT USE THE PLASTIC ONES LIKE THE FACTORY IT WILL BREAK....and add an extra half quart of oil
    1997 RCSB Z71 5.7 Vortec, 411 PCM , Ultra gauge, SS Headers, EGR Delete, Magnaflow Hi-flow cat assembly, Cat back with flowmaster 40, Transbuilderguy Built 4l60E, Yukon Duragrip Posi 3.73, 33 x 12.5 Maxxis Big Horn
    Aug 2010
    Wisconsin
    That they are, but if your pump went out I think I'd go in and look everything over just because. Just my 2 cents, take it for what it's worth.
    Burnsville
    Im pretty sure it's the pump I've had this ole girl since she was new. Done all the repairs myself, I'm a heavy machine
    Operator/mechanic. The pressure was up and down a couple weeks ago and has now is at 0 all the time except for a cold start she'll push 50psi then drop to zero immediately. When it's warmed up from a start it's pushin 1 psi haha.
    From a cold start when there good oil pressure for the few moments I have it the motor purrs drops than it ticks a bit not much just a bit. Deffinitly not a bearing I would hear that and deffinitly not the sensor I wouldn't hear a tick when the pressure dropped. I also just replaced the distributor gear and stoped the sluggish issue. But since the oil issue the sluggish is back and leads me to think the gear witch is on the oil pu
    P that aligns with the distributor witch the cam runs both is worn. Oil pump side that is.
    SW OH
    Nothing wrong with the pump.
    If it ACTUALLY had ZERO oil pressure, it would have blown up A LONG TIME AGO.
    Believe that the motor still works. Disbelieve the gauge.
    Sounds to me like it needs an oil pressure sending unit.
    May 2009
    Dallas
    when sending units fail, they go HIGH..
    Aug 2010
    Wisconsin
    One of the motors we had did that. It had a spun bearing or two.
    I would tear that motor out and down.
    I'd also like to take this time to age with para driver.
    SW OH
    Sending units can fail by reading wrong either way; or by leaking. If one leaks it's almost always electrically fornicated as well.
    It's CHEEEEEEEEP and EEEEEEEEEEEZIE to replace. Try it first.
    Burnsville
    I will try the sending unit this morning I know where it is it's a 5 min fix hope it works I just don't think it's that.
    Aug 2010
    Wisconsin
    Good luck hopefully that works.
    SE Michigan
    Quote Originally Posted by para driver View Post
    nope, most I see fail and read low
    2000 Silverado 6.0 4L80E 2wd
    Burnsville
    Well I should have saved the 20 bucks but no biggie the sending unit is installed and just as I expected no fix. But now it reads differently from before before it wouldnt read over 1 while now it shoots up and down from 40 to 0 then drops to 0 at idel. Very strange maybe it's a gauge. Next I will put a mechanical gauge directly on the engine. Where is that installed?
    SW OH
    Same place the sending unit goes
