Thread: how do i remove 97 c1500 dash?
Results 1 to 19 of 19
    Mar 2011
    central valley,ca
    i got a good deal on a 97 silverado dash. i want to know how do i remove and install on my 91 gmc sierra?
    Registered User old chevy man's Avatar
    Mar 2011
    Homer, IL
    Re: how do i remove 97 c1500 dash?
    A 97 dash will not fit in a 91, the interior is diffrent.
    Registered User bayko's Avatar
    Apr 2011
    Vancouver, BC
    You will have to change the door panels with the dash for it to fit.
    2003 GMC 2500HD Duramax
    6" Lift, 35s, 4" straight pipe, PPE stage 3, boost valve, CAT filter adapter
    1991 K2500 6.2L Diesel SM465 swapped(SOLD)
    ( o )( o ) 1badgmc's Avatar
    Aug 2001
    Wichita Falls, TX
    Quote Originally Posted by old chevy man View Post
    A '97 dash will fit in a '91 just fine. It just takes some work.
    '91 GMC Sportside
    '98 Chevy Suburban
    '88 Chevy Crew Cab Dually
    '13 Ford Focus Titanium
    -- Jason
    Mar 2011
    central valley,ca
    but does any one how i go about removing it?
    i tried but its still bolted to something?
    Mar 2011
    central valley,ca
    Quote Originally Posted by 1badgmc View Post
    the dash has the airbag option. i dont knoe if anyone has done this before
    Aug 2001
    Wichita Falls, TX
    Quote Originally Posted by valleyk5 View Post
    It's been a while since I pulled one, but there aren't many bolts holding it. 2 or 4 in the footwells and a few in the defroster vents. Unbolt the steering column so it can drop and allow you to tilt the dash forward and pull out all the wiring and ducting. It's a pain.
    '91 GMC Sportside
    '98 Chevy Suburban
    -- Jason
    Aug 2001
    Wichita Falls, TX
    Many, many people have done this update. The passenger airbag wasn't an option on half-tons. It was standard. 3/4- and 1-tons didn't have the passenger airbag. Instead they had a pocket in the dash where the airbag would be. Many who do the update use this pocket or fill the hole with screens or game systems. You could leave the bag in place, I suppose, but it would be non-functional.
    '91 GMC Sportside
    '98 Chevy Suburban
    -- Jason
    Mar 2011
    central valley,ca
    thnks for the help ill give it a try today.
    by the way man how did you fill your taillights on your 91 stepside?
    Aug 2001
    Wichita Falls, TX
    Good luck.
    I stood around and watched my bodyman do it.
    On an '88-'98 sportside bed, the best taillight fillers money can buy are already on the truck: the stock taillights. So, those are my fillers. They're filled using Marine Tex and a little bit of fiberglass.
    '91 GMC Sportside
    '98 Chevy Suburban
    -- Jason
    Jul 2011
    jacksonville fl
    if its like my 97 i had some bolts in the glove box under the air bag one in pass side kick then one on driver side kick the the 3 screws across the top and i had to pull the wiring threw the fire wall
    somewhere else
    Quote Originally Posted by realpitbull View Post
    Pretty much this, other than don't forget that one stupid screw to the lower right of the steering column area; it's down low, on a support bracket. Sumbitch will hold the whole dash up. Just another one of the 7mm-headed trim screws.
    Richard
    Jul 2011
    jacksonville fl
    yea i forgot about that pita one its a 7mm and it will hold the whole dash in
    Mar 2011
    central valley,ca
    thanks guys. but the guy i bought it from actually took the time to remove it himself and only charged me 30 bucks for it. but know i got to find out if the 91 and 97 bolt up the same way. also i want to fill the airbag part with something. i was thinking a screen or if possibe a small "drink" cooler haha
    Mar 2011
    central valley,ca
    Good luck.
    ok so im guessing he used the fiberglass first and the marine tex to smooth it all out?
    Aug 2001
    Wichita Falls, TX
    Yes
    '91 GMC Sportside
    '98 Chevy Suburban
    -- Jason
    Oct 2011
    I need help with this to
    Registered User 98nightmare's Avatar
    Sep 2010
    South GA
    Theres threads on here about doing the swap.. also the gauges are different and theres threads on that too... rob the ductwork from the newer dash too! Most of the wires that will hold you up on the dash removal are the headlight, the couple black boxes mounted to the metal dash cross bar kinda between the column and lighter plugs, and the A.C. unit wiring is accessed easily once glove box is removed.. idunno bout the older dash but these will tick ya off trien to remove the newer dash.. There are also two bolts under the passenger airbag accessed thru glove box hole.. can't remember if theres much more than whats already been mentioned. Good luck man
    Mar 2011
    central valley,ca
    thanks guys for the help..i wish i would have took pics of my truck with the cables all over the place..i ended putting my old dash back on.
    because i couldnt make the gauges work. i think ill just part with the dash. or give it a go later on.
