Thread: OBD2 won't communicate with scanner...need help fixing it.
Results 1 to 10 of 10
    May 2008
    arizona
    Failed the emission test today. They couldn't read the obd2 system for some reason in my 04 5.3. Tried it at home with my scan tool and it wouldn't communicate either. I checked the fuses and they all seem to be fine. Any where else to look besides wiring? anybody got a wiring diagram or know what I should trace it to?
    Registered User southcarolina12's Avatar
    Jul 2011
    south carolina
    Re: OBD2 won't communicate with scanner...need help fixing it.
    did you check the cig lighter fuse? mine was blown and did the same thing.
    2000 silverado z71, 315 mud grapplers, leveled, k&n intake, flowmaster 40, cat delete, hid, strobes, bully dog tuner, msd ignition, e3 spark plugs, polished throttle body, shift kit, long tubes, z06 cam
    May 2010
    Deland, Fl
    is the key in the on position? i know it's a dumb question but ive seen it happen
    '94 GMC C1500 RCLB, DD - Sold
    SE Michigan
    yeah, check the fuse
    2000 Silverado 6.0 4L80E 2wd
    May 2008
    arizona
    No fuse is fine. Checked it and even replaced it with another fuse just to make sure it wasn't a faulty one. No luck.
    check all your underhood fuzes then.
    Registered User gungyspliff's Avatar
    SC
    What kind of scanner is it? My Snap On will not work unless I put the right personality key in it. I assume you checked it to make sure it will work on another vehicle.
    Registered User GirchyGirchy's Avatar
    Aug 2011
    Central IN
    I'd check the connection to the OBDII receptacle. Is the scanner getting power? Find a wiring diagram and see if you can check continuity between the receptacle and further down CAN channel.
    ~RED~ chevyman98's Avatar
    Jan 2009
    texas
    i had the same problem , my obdII didnt work, found out that the cig fuse controls the obdII port too.
    2012 greystone grey chevy silverado crew cab 2wd stock
    May 2008
    arizona
    Well finally got down there looked at it. The orange wire was sliced for some odd reason. Somehow must have got cut by something sharp. spliced it together and it works just fine.
